Go to Post First, corndogs and now cowbells... when will you make the pain stop, Frank?!?!?! - barn34 [more]
Unread 13-01-2004, 12:52
Fred Hord Fred Hord is offline
Fred Hord is on a distinguished road
Re: Pneumatics holding their position
Originally Posted by sanddrag
After the match when the control system is disabled, will pneumatic cylinders hold thier position still? Sorry for the newbie question but my team is very experienced in everything but pneumatics.
If you use the double solenoid valve it will hold the cylinders position when power is turned off.
Unread 14-01-2004, 22:06
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Originally Posted by Cory
They will hold their position assuming you still have pressure in your accumulators, at least thats what Ive always found the case to be when we've used them.
Cory
a double solonoid valve will hold its position.
A single solonoid will shift to its rest position -- so it either will hold its position if it starts in rest position or it will shift(and the cylinder its attached to will also shift) if you have it in activated position when the match ends.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 14-01-2004, 23:22
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
*BE CAREFUL WHEN TIGTENING*
we had a bit of a snafu lat year with the port where the 125 psi presure release valve was connected leaking last year, so my associate wipped out the 12" long wrench and tightened it, cracking the port on the compressor, and breaking the valve. that compressor is now irriparible...
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 14-01-2004, 23:39
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
The easiest way to have a pneumatic cylinder stay in position after your robot has it's power turned off, is to use the double selenoid valve. If you notice that you have a leak in your system, the easiest way i found to find a leak, is to take a cup of soapy water with a painting brush and go over all the connectors in the system. Turn the system on, if you see a bubble appear, you have a leak in that particular valve. Take the connection off, put some more teflon tape, tighten the connection enough, and re-check. We had this problem last year and this solution solved everything.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 14-01-2004, 23:49
resident insomniac
Team Role: Student
I guess a mechanical solution would be the chinese finger trap idea, that maybe after the cylender extends, it extends passed a spring loaded switch. like how classroom doors are locked, so you cant turn the knob on the outside, but the latch can retract when you close the door. that would be the faisafe, but if you were off, you might bend the cylender, or it might get stuck. I'd stick with the double solenoid and leak prevention though.
team motto:
AFLAC 2002
Unread 15-01-2004, 15:25
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
briholton is on a distinguished road
I keep reading about the 60 psi with a 2 inch bore, yada yada and people multiplying area by pressure to get force. I have yet to see someone account for the fact that in pressurizing the 2 inch bore cylinder, the overall pressure goes WAY down to less than 60 psi and i know my compressor can't recover that quickly. The tanks are small..... Am I doing something wrong, or does this make sense? That is, that you need to account for the overall pressure drop in figuring theoretical force exerted by piston.
Unread 15-01-2004, 15:54
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Brian,
If you've set up your system correctly, your tanks will be pressurized to 120 psi, and the line is then regulated down to 60 psi. This allows your cylinder to fill with 60 psi air, and the line to very quickly (I'm tempted to say almost instantaneously) recover to 60 psi.
Unread 15-01-2004, 16:36
ChrisH ChrisH is offline
Generally Useless
Originally Posted by gwross
Brian,
True, but continued operation will draw down your air supply. So you need to balance cylinder size with the storage capacity of the system. In general use the smallest cylinder possible to do the job. This will greatly reduce the amount of air you consume. The volume used by one of the largest cylinders is roughly equivalent to the volume in one of the storage tanks. Since we can store at twice the operating pressure that means your first shot will be at 60 psi. But if you vent and immediately cycle the cylinder again two or three times then you will see a drastic reduction in air pressure and thus force from the cylinder.
Just another of the limitations we have to live within...
Christopher H Husmann, PE
"Who is John Galt?"
No Pneumatics This Season?? BBFIRSTCHICK Rumor Mill 9 18-01-2003 13:21
Pneumatics hose Brett W Kit & Additional Hardware 10 09-01-2003 15:35
Looking for Co-op position archiver 2001 0 24-06-2002 03:45
pneumatics archiver 2000 3 23-06-2002 22:58
