re designing old mechiniism
(from a student member of the team
![]() can a preivous years mechinism be drastically modified ( same basic structural parts but differently configured) and incorperated into the new robot (1 pistion instead of two- move to a non articulate wrist- different sized hoops to grab ball)-] its the same in concept just differently put together team 497 info guru |
Re: re designing old mechiniism
Let me point your attention to Rule R09 from section 5, The Robot, of the FIRST Rulebook:
yes the manual was read and debated ad infinitum by the team
And by your interpretation everything on your bot must be brand new design so you could not fabricate the same drive train as you have used in the previous years as long as we go buy the same aluminum stock/ and order new busihngs and pins and order a new piston to power it that EVERY OTHER team has access to getting making it we can essentailly build the same device-i as long as i dont reuse the old material from the original mechinism as a whole and change it i read the rule as you cannot unbolt a mechinism from a old robot and bolt it on to a new robot and use it- if you re create the same mech from new parts that is ok Last edited by Andrew Dahl : 13-01-2004 at 18:20. |
I think we are saying the right things but getting the meanings of the words mixed up.
a design is something drawn on paper - you CAN use old designs a mechanism is a physical assembly with fabricated components - you CANNOT take a mechanism or any team-fabricated parts off old bots and use them this year. we are saying the same thing, but using the words differently. |
yes thanks
well off to the machine shop i go then- that will save my desing team fits coming up with a new "ball handler"just need to work on the new components |
NO NO NO NO NO!!!!
you absolutely cannot use mechanisms from previous years designs unless it is something that can be COMPLETELY purchased by all teams off the shelf it doesnt matter if you modify it or not. what you CAN do is take an old design and make a new copy of it - as long as all the fabricated parts are fabricated after the 2004 kickoff. 95% of what we use in engineering (and on our robots) was designed and fabricated by someone else (all the parts they give us in the kit for example) you are free to make customs parts of your own design, or of someones elses design, or from a white paper on this forum - but you have to build and fabricate ALL the parts this year. |
#7
for the official wording, see section 5.2.5 <R09> of the beloved manual :c)
#8
You can use the same design, redesign it if you want, but all fabrication needs to be new for the season, hence forth giving rookies and such a fair opportunity...prof. grac.
See above post as well, you got there faster than i could ![]() Last edited by Ragin_Kage : 13-01-2004 at 17:17. Reason: Same as previous message |
| How do YOU start designing? | Gadget470 | General Forum | 12 | 29-12-2003 14:24 |
