Go to Post Blue Nitrile Tread is the best smelling wheel tread. #thingsyoufigureoutat2AM - Ginger Power [more]
Unread 12-01-2004, 20:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How to make gears mesh properly.
Let's say you have a gear with a pitch diameter of 1" and then you have another one with a pitch diameter of 2". Would you place these gears exactly 1.5" apart? Or would you leave a few thousandths for backlash? Is a little backlash already accounted for in gear sizes? If you must account for it yourself, how do you know how much more to put them apart? Thanks
Unread 12-01-2004, 21:07
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Re: How to make gears mesh properly.
You should generally mesh the gears using the pitch diameter, so 1.5" would be correct. You do not want to go any closer than this for sure, so if you are worried about tolerancing you could make them a little bit further apart. Also, if it is a large gear ratio, then the tips of the gears will interfere, and two teeth or more will touch at a given time. This causes the gears to be loud and wear each other down. So you might want to add a couple thousandths. I suspect the real engineers will be able to provide better advice, which I am curious to hear since I'm designing a gearbox for RoboCup as well. I'll post how to actually calculate what distance to use if I can successfully interpret my "Machine Component Design" textbook.
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 12-01-2004, 21:17
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
I think for calculating the distance, there are three #'s that should be summed to get your center distance. The outer radius of the first gear, the inner radius of the second gear, and the working depth of the gears that are being used. The working depth takes into account that gears do not mesh all the way to the bottom, adding an additional thousandth or two will give you a good center distance #. I am not positive on this though....
-Rc
Unread 12-01-2004, 21:36
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Good question. Keeping tight tolerances on center-distance spacing when designing gearboxes is a good thing to do. In your case, it is OK to specify 1.500" distance if the fabricator keeps a tolerance of +/- 0.001".
Another way to dimension it would be to call out 4 places, at 1.5000". Traditionally, the tolerance for this dimension would be +/- 0.0005".
I know that there are other engineers who say to add 0.002-0.003" to the center distance. That will work also, as it is a more conservative way to design. It will add a bit of backlash (not sure how much).
It really depends on the level of quality and tolerance your fabricator can handle. If they are very good, go with a four-place tolerance. If they are just OK, then add a few thousanths for backlash.
Good luck,
Andy B.
Unread 12-01-2004, 22:35
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Ryan Curry
I think for calculating the distance, <snip> ...I am not positive on this though....
-Rc
Then don't answer!
The see Andy's anwser -- I have not yet read it, but I know Andy and I suppose you will be fine with what he recommends.
Joe J.
P.S. The addendum and dedendum of standard (i.e. off the shelf) gears is typically 1/DP and 1.2-1.25/DP This means the standard pitch dia is NOT the average of the Root Dia and the O.D. For the record, In FIRST, I almost always add a few thousandths to the theoretical center distance. extra backlash will almost never kill you in FIRST. Jamming the gears together because the gears are a bit out of round will eat up your power like opening the frig on a hot summer day.
Unread 13-01-2004, 11:34
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
One of our machinists showed me a trick. You can put a piece of ordinary notebook paper between the two gears and then mash them together as tightly as you can. You can then measure the center distace with your calipers. In my experience it is 0.002 to 0.003 inches more than the pitch diameters would indicate. The result are gears that spin freely with almost no backlash. Basically what Joe J. said.
Some teams I've talked to use the pitch circle spacing and then wear them in with a few hours of operation. I think I remember someone saying they let them run over night.
Unread 13-01-2004, 15:53
DaSpyder's Avatar
DaSpyder DaSpyder is offline
Dat $@#$@#$@#$@# Tall Kid is Back
AKA: Dan
#0999 (C.R.A.S.H. (Cheshire Robotics And Sikorsky Helicopters))
Team Role: Student
DaSpyder is an unknown quantity at this point
Send a message via AIM to DaSpyder Send a message via Yahoo to DaSpyder
Gears
Does anyone have any direction as to where i can find some decent 39 tooth gears, and about how long they will take to deliver. Thank you all for your help and enjoy the 6 weeks this season brings. I look forward to seeing all who plan on attending the UTC New England Regional!!!!!!!!!
Unread 13-01-2004, 20:19
Matt Reiland's Avatar
'The' drive behind the drive
Re: Gears
What pitch are you looking for?
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 13-12-2002 18:50
Time for new rules! archiver 2001 11 24-06-2002 02:01
How do i make gears in inventor? mnkysp6353 Inventor 1 16-01-2002 02:31
