Vacuum
Ok, I was wondering if it was legal to use a venturi style vacuum genorator. Its just a little box then when positve air pressure is blown over it, it creats negative air ressure at the other end. Probably wont use it anyhow, but it is somthing we are looking into and would like to know the legality of!
Re: Vacuum
If you can make one with off-the-shelf parts, or ones that you have machined, and only motors from the kit, then yes, it would be legal.
However, if there was any motive force, in say the fan/blower, it would be an illiegal motor. |
Re: Vacuum
What if it IS an off the shelf part all together
Re: Vacuum
you could probabally do what you are talking about, but I dont think it will create much vacuum.
in the past teams have used a pair of pnuematic cylinders to create vacuum. have a pressurized cylinder pump a second one to draw a vaccum at one end. |
Re: Vacuum
Well, 2 points
Vanturi style is what they do in industry and create MUCH more vacuum, i just got home from prototyping We were planning on using the cylenders, even thogh they create less vacuum, they reqire a NON-continuous flow |
Re: Vacuum
you can also create a vacuum using a kit motor and a cam arrangement which repeatedly creates a draw/push stroke, then you retain the vacuum using a no-return valve on one side of the cylinder. This is something our team has been looking at this season
![]() I think that this might be more successful than what you are proposing, I believe that some teams did this last year as well to develop a vacuum, with a fair amount of success. |
#7
Re: Vacuum
well, we need somthing with a quick vaccum produced to take out the air in our large cup, the cup is larg to allow for sloppy driving and positioning, lol
the ventri works WAY better than i thouht it would, you people should puick one up just to try it, ive seen them lift #30 boxes at my dads works. pretty impressive! |
#8
Re: Vacuum
yeah but what were they powered with? the compressors we have are pretty whimpy - something like 1/8 HP or less (rough guess) and they dont supply a large volume of air.
please dont let me discourage you- definately try the venturi and see how it works - Im only tossing out options for your consideration |
#9
Re: Vacuum
i know its not a good idea bc lack of volume of air, im just sayin, dont underestimate its power! try it out, i was REALLY impressed!
#10
Re: Vacuum
I do not think that you have enough compressor "umph" to efficiently implement a venturi vacuum generator. I also would quicly discount centrifigal vac pumps (there heavy- upwards 100 lbs) and turbo molecular vacs (expensive-upwards $15000).
I would try to drive a pnumatic cylinder with a cam on a motor with one way valves that seems like the easiest, lightest, most cost effective solution. good luck! -Andy |
#11
Re: Vacuum
Re: Vacuum
"We were planning on using the cylenders"
I realize all this, and had already butlt the prototype for it before I even posted. I just wanted to know the legality of it. |
#13
Re: Vacuum
[quote=Rickertsen2]But since one way valves arn't really legal either, you can use a double solenoid in place of one, as long as you know when the cylinder is extending and retracting.[quote]
Actually, the flow restrictors in the pneumatics kit only restrict flow in one direction (the direction with the small arrow). Therefore, if you tighten it all the way down, it functions as a one-way valve. |
#14
Re: Vacuum
Q&A hass said that Vacuums are not allowed, but suction cups are. As of right now, there are several different followup questions as far as using pneumatics and fans to create a vacuum. Tehse questions stand unanswered. It is clear however that venturi-style vacuum generators are not allowed.
#15
Re: Vacuum
We tried this last year and got very little suction as a result of little air flow out of the compressor.
There is also a rule against custon pneumatics. Why in the heck would you want a vacuum anyways? |
| Vacuum | nwagers | Pneumatics | 16 | 31-10-2003 15:57 |
| Suction Cups: How? | Kai Zhao | Pneumatics | 25 | 04-02-2003 19:02 |
| compressor? | BBFIRSTCHICK | Pneumatics | 11 | 22-01-2003 07:12 |
| Stacker with a vacuum | Miles | General Forum | 15 | 17-01-2003 23:35 |
| Next Question - Check Valve | archiver | 2001 | 7 | 23-06-2002 23:18 |
