Re: .dwg from Inventor
Thanks, that worked perfectly. There is only one more problem, the drawing is supposed to be on D sized paper, and it looks fine in Inventor, but when I convert it, the page in AutoCAD is taller. How do I change the size of the page in AutoCAD?
The sheet size has to do with what size paper AutoCAD thinks you want to print onto and can be adjusted in "page setup" under FILE. To be honest with you I've never had to make a drawing with Autocad, I've only used it as a stepping stone between CAM and solid models (and to communicate with people still using 2D CAD systems). I have no clue how to change the border/drawing template, but if it's anything like solidworks and inventor you can find "Sheet properties" somewhere and adjust the paper size. OR You can copy all of the geometry out of the drawing and into a new blank file. You could draw a border / title block quickly enough (if one is neccessary). I have to use autocad tomarrow, I'll make a mental note to look into this for you. Greg |
Thanks so much for all the help, I figured out all the problems and it's ready for plotting. Thanks.
| student inventor | matt111 | Inventor | 7 | 13-01-2004 17:22 |
| Users Guide To Inventor | R2K2D2 | Inventor | 5 | 11-01-2004 14:09 |
| Inventor -> 3D Studio | Adam Shapiro | Inventor | 1 | 18-01-2003 12:35 |
| Autodesk Inventor Award 2002 | Digo | Inventor | 1 | 24-03-2002 12:07 |
| Inventor and Virtual Kit of Parts | Torchin | Inventor | 1 | 09-01-2002 09:59 |
