Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
Unread 14-01-2004, 07:33
m0rph3us's Avatar
m0rph3us m0rph3us is offline
AKA: Andre
#0293 (Spike)
m0rph3us will become famous soon enough
Send a message via ICQ to m0rph3us Send a message via AIM to m0rph3us Send a message via MSN to m0rph3us Send a message via Yahoo to m0rph3us
360 Servos
Has anyone seen servos that can rotate 360 degrees and where I can buy them? Because the ones with EduRobot only turn about 270.
Andre
Team S.P.I.K.E.293
Unread 14-01-2004, 08:42
Dung H Cao's Avatar
Dung H Cao Dung H Cao is offline
None #0397 (Knight Riders)
Dung H Cao is just really niceDung H Cao is just really niceDung H Cao is just really niceDung H Cao is just really niceDung H Cao is just really nice
Re: 360 Servos
Try modifying the servo yourself
http://www.fortunecity.com/marina/ne...Bas_360_R.html
or purchase at
http://www.hobbyengineering.com/SectionM.html
I don't think either of these options will meet 2004 Robot rules.
Good luck
Unread 14-01-2004, 20:22
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: 360 Servos
While such servos are made, FIRST restricts us to what came in the kit of parts. If you only need one 360 servo you could mount a servo on top of another servo which would give you twice the rotational range.
If you wish to use a servo as a speed controller / motor all-in-one and it's not for a FIRST application, you can modify the edu servo(s).
If you want to do something similar to what was shown at kickoff by the IR tracking bot but have a wider range of sensor vision you will probably have to build your own servo (unless they put a stepper motor in the kit this year, I haven't looked through one yet).
If your team is in possession of a talented programmer you might try attaching a rotational encoder to a motor driven shaft. This will allow you to turn the shaft (through the motor) and sense how much the shaft has actually rotated (by counting pulses from the rotational encoder). Note that a rotational encoder (mechanical or optical) will send a pulse to your robot controller X times every revolution (some pulse every 25 deg., some every .1 deg.). This approach would allow you to detect the angle your shaft has turned over a unlimited range of rotation.
You could also use a variable resister to accomplish this, just like the servo in the kit of parts, but the variable resister would have a limited range of rotation, just like the one in the kit of parts.
Hopefully at least something I said made sense.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Creative uses for servos? dddriveman Motors 34 19-07-2003 00:33
360 degree pic of WILDSTANG archiver 2001 2 24-06-2002 01:31
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
Anyone on team 360... archiver 2000 0 23-06-2002 22:58
servos, chapulas, cylinders and Skyway...in other words... Jessica Boucher Motors 7 14-01-2002 19:36
