Re: telescoping arm
Hey Guys I'll shed a little light on our arm from 2003
It took 4 solid weeks to work out all the bugs in the telescoping mechanism. No pulleys or cables in that arm either. We used "fish tape" which is commonly used for running electrical wires thru conduit. it's like a 15' long piece of spring steel about 1/4" wide that we moved with two rollers. When retracted the tape was wound up inside the big brass ring that you see on the side of the mechanism. To tell the truth that thing was a pain in the $@#$@#$@#, it worked really well but only 60% of the time. That is until the bot fell on the mech in the first practice heat, from that point on it worked so well we could shoot the smallest extension like a spear, Almost lost my head the first time it happened! |
Re: telescoping arm
My old team (442) built an arm that was 30' long in 2002. They used it to reach over all the other bots and goals and back to the home zone area. It used strings/pulleys/cables whatever. I'm not sure what kind of string material they used, but I know pulleys were involved.
Although I never really approved of building it, the few times it worked were kind of impressive. That is, until the top snapped off, swung by the string, and almost killed a referee. But, eh, it's all the same. ![]() |
Re: telescoping arm
In 99' Team 384, used an elevator to achieve the play. It was our first year, and I wasn't on the team because I was in 8th grade, but it used a pully system to achieve a 7 foot gain I believe. You could use the same system of pullies to get the height. But I would worry if you were to use the pullies to lift the bot as well, the cable could snap with that much weight on it... I'm not sure. I'm beginning to think that the bar is somewhat like stacking of last year, really great if you can do it, and it helps, but you can easily win with out it...
If you are using the device for grabbing the multiplier balls, don't go up and down, stay in a fixed location with an arm that moves from a stationary elevated point. It makes it so there is less to break. Ivey |
| Reflected Inertia? | archiver | 2001 | 9 | 24-06-2002 03:50 |
| anyone use an arm to help balance | archiver | 2001 | 8 | 24-06-2002 02:46 |
| Controlling Arm travel - Limit Switch or Mechanical Stop? | archiver | 2001 | 8 | 23-06-2002 23:55 |
| telescoping arm & ten second rule | Ben Mitchell | Rules/Strategy | 4 | 18-02-2002 21:37 |
| Robot Controller arm | David Kelly | Technical Discussion | 0 | 28-06-2001 16:37 |
