Go to Post Surely, we've seen enough new and interesting implementations of technology in FIRST that we won't keep limiting our imagination to the tried and true. - Madison [more]
Unread 14-01-2004, 11:18
jjv jjv is offline
jjv is an unknown quantity at this point
IR Beacons
I know that FIRST has said that the IR beacons will both be at the same frequency, but different Pulse Widths. Has anyone seen anything that indicates what these will be?
I'd like to make a mock up of these for use in practices.
Unread 14-01-2004, 11:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR Beacons
It's discussed in this thread and here's another one. I've posted an illustration of what the waveforms look like here.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-01-2004, 10:10
bfvaneyck bfvaneyck is offline
AKA: Bruce Van Eyck
FRC #0537 (Charger Robotics)
bfvaneyck has a spectacular aura aboutbfvaneyck has a spectacular aura aboutbfvaneyck has a spectacular aura about
Re: IR Beacons
Do we know the P/N for the IR emitters?
Unread 15-01-2004, 11:34
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: IR Beacons
From the sheet that came with them (the one with the schematic) the P/N is EOD-EL-1L2
Unread 15-01-2004, 11:38
AKA: Bruce Van Eyck
Re: IR Beacons
How about the manufacturer?
Unread 15-01-2004, 11:40
FRC #2429
Re: IR Beacons
I imagine just about any infrared LED operating at a peak wavelength of 940nm will work. The variables that immediatly come to mind are output power and radiating pattern. A data sheet for the part used to develop the IR beacon can be found here. They're available from Digi-Key.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-01-2004, 12:13
AKA: Bruce Van Eyck
Re: IR Beacons
Thanks Kevin,
I was looking for the specs so that I could find an emitter in a T1-3/4 package. We host competitions at our school and I need to make some decent beacons for the field.
Unread 15-01-2004, 12:34
FRC #2429
Re: IR Beacons
Thanks Kevin,
Here is some stuff to consider for those building their own fields: The Lumex devices are what FIRST will be using on their official playing fields. Each official beacon will use seven LEDs. One important note: If you're building an official field, with two beacons running at the same time, drive the beacons with one EDU-RC because you don't want the IR sensors "seeing" multiple pulses arriving at the same time. Oh, another thing to look out for is beacon reflections.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-01-2004, 17:41
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: IR Beacons
That brings up a question I've been wondering about. What about regionals with multiple fields (or Atlanta, for that matter)? We've only gotten to play with the emitters/detectors a little bit so far but one single IR LED has no problem filling our entire practice room (which is a good deal larger than the field) with IR...
Unread 15-01-2004, 20:49
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Re: IR Beacons
Would there be a way to determine which of the two identical beacons from two separate fields arrived first, or is that out of the question?
I'm not very edumacated on IR. I'm pretty sure that everything would be fine if FIRST installed some lead walls between the fields (though I can't see that happening), but other than that I'm out of the loop.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 15-01-2004, 21:29
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: IR Beacons
heh, or just get a wall of spectators
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 11-02-2004, 17:05
AKA: Bruce Van Eyck
Question Re: IR Beacons
Do we know the positions for the beacons, i.e. if you're standing on the blue alliance side of the field, is beacon #0 on the left or the right?
