Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 14-01-2004, 12:30
Kevin Watson's Avatar
La Caņada High School
FRC #2429
An Example IR Beacon Tracking Assembly...
I've posted high resolution pictures of the IR trackers that we built to test the IR receiver/tracking/navigation software. You can find 'em here: http://kevin.org/frc/tracker. The trackers that we built for the kick-off demo consisted of two lego-based arrows that had a sensor hot glued to each of their sides. The lego arrow assembly was then secured to a servo.
I'll soon have software that will allow you guys to try out the tracking functionality without having to run the navigation software.
As this stuff is pretty easy to fabricate and has a high potential payoff (more game points, knowledge and fun), I'd encourage you to try this technology out.
-Kevin
Kevin Watson
http://kevin.org
Official Beacon Tracking Code Posted Kevin Watson Programming 41 18-02-2004 21:04
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
Tracking Canadian teams at nationals! blueWarrior Championship Event 15 15-04-2003 21:03
How much can the window assembly lift? archiver 2000 9 23-06-2002 22:59
Driving constraints in assembly Jan Olligs Inventor 0 25-02-2002 07:11
