Reusing gearbox & bearings
Does anyone know if we are allowed to use the same gearbox and bearings that we used last year?
Re: Reusing gearbox & bearings
if it was a custom gearbox your team designed and fabricated - then you can build a new copy of it, but you cant use the same physical mechansim
if you are talking about the gearbox that FIRST gave us in the kit of parts, then yes, its the same this year - so you could resuse the same one - but I wouldnt recommend it the gearbox supplied by FIRST has a plastic housing, and you dont know what kind of a beating it took last year - it might be stressed or have fractures in the plastic that could give out in the middle of the match. The one in our practice frame from last year has cracks in it (where the bearings are held in) - we beat it up pretty good while debugging the auton code - slamming from full forward to full reverse in one CPU cycle will do that! :^) Definately use all the new parts from the kit whenevery you can. Last edited by KenWittlief : 14-01-2004 at 21:51. |
| A question about gearbox design . . | Frank(Aflak) | Technical Discussion | 14 | 02-10-2003 14:57 |
| Shift on the fly LEGO gearbox | rlowerr_1 | Robot Showcase | 17 | 14-07-2003 23:33 |
| A little tip about those drill transmissions and bearings | archiver | 2001 | 6 | 24-06-2002 00:22 |
| Skyway wheels w/o bearings | ahecht | Technical Discussion | 4 | 22-01-2002 01:25 |
