Go to Post I have photos of students working the lathe dressed for a concert! Makes me wish for a formal dress night at robotics. - Mark McLeod [more]
Unread 14-01-2004, 18:20
BlacKnight6604 BlacKnight6604 is offline
BlacKnight6604 is an unknown quantity at this point
Reusing gearbox & bearings
Does anyone know if we are allowed to use the same gearbox and bearings that we used last year?
Unread 14-01-2004, 18:49
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Re: Reusing gearbox & bearings
Using the Part Use Flowchart from page 10 of Section 5- The Robot from the manual, I would say you can use the bearings as long as you account for their original cost(since they are off the shelf) but not the gearboxes(since they were fabricated before the 2004 Kickoff). If you still wanted to use the gearboxes, you could always use the same design but just re-machine the parts that were machined by the team before.
Unread 14-01-2004, 21:49
if it was a custom gearbox your team designed and fabricated - then you can build a new copy of it, but you cant use the same physical mechansim
if you are talking about the gearbox that FIRST gave us in the kit of parts, then yes, its the same this year - so you could resuse the same one - but I wouldnt recommend it
the gearbox supplied by FIRST has a plastic housing, and you dont know what kind of a beating it took last year - it might be stressed or have fractures in the plastic that could give out in the middle of the match.
The one in our practice frame from last year has cracks in it (where the bearings are held in) - we beat it up pretty good while debugging the auton code - slamming from full forward to full reverse in one CPU cycle will do that! :^)
Definately use all the new parts from the kit whenevery you can.
A question about gearbox design . . Frank(Aflak) Technical Discussion 14 02-10-2003 14:57
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
