Go to Post Luck *good or bad* and opportunity will always affect what happens to teams. - Brian C [more]
Unread 14-01-2004, 18:02
AlphaOmega870 AlphaOmega870 is offline
AKA: Mike
#0870 (Southold RICE)
AlphaOmega870 is an unknown quantity at this point
Send a message via AIM to AlphaOmega870
Question New Joysticks...Good or Bad Choice by FIRST?
Our joysticks are insanely sensitive. When moved, they do not return to zeroed position by themselves. Is there any other way to adjust sensitivity?
Unread 14-01-2004, 18:52
josh_johnson josh_johnson is offline
#1020 (Indiana Prankmonkeys)
josh_johnson is an unknown quantity at this point
Send a message via AIM to josh_johnson Send a message via Yahoo to josh_johnson
Re: New Joysticks...Good or Bad Choice by FIRST?
The easiest way to do this would probably be to add a deadband in programming by changing the output value to the motor to 127 if the joystick is within a certain range of 127. For example, if pwm01 and pwm02 are controlling the robot drive, you could insert the following code in the Process_Data_From_Master_uP function in the user_routines.c function:
int deadband = 20;
//the above value may need to be more or less depending on how sensitive the joysticks are
pwm01 = (abs(pwm01 - 127) <= deadband ? 127 : pwm01);
pwm02 = (abs(pwm02 - 127) <= deadband ? 127 : pwm02);
and add this function to find absolute value to the user_routines.c file as well:
int abs(a) {
return (a < 0 ? -a : a);
I have not tested this, but I do believe that it should work.
5! * (4! - 3! - 1!) / 2!
Unread 14-01-2004, 19:52
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
The new joysticks this year are good and bad in there own.
Good
-More buttons
-Fits your right hand comfortably
Bad
-Doesn't fit left hand
-No wheel
-Can't use two joysticks on the same port
-Anything else you can think of
Unread 14-01-2004, 20:07
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Good
-More buttons
Bad
-No wheel
Look again There are two wheels to be exact.
I like them...but I wish they'd sent a left handed, too! What about left handed drivers? Lefties unite!
OK, not really...
I do like the extra buttons and the little d-pad in the middle very much. Fun stuff for us programmers to play with!
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 14-01-2004, 20:09
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
theyre nice But Only right handed.
For a Driver like Me who likes to use two sticks to drive the new sticks would be a bit awkward i have the idea of using an old stick on the left a new one in the right and using the other new stick for an operator. but now that you say they have difrent sesctivity... im thinking i only would use the old sticks for driving.
Using one stick In a ,2 wheel drive, tank or somthing similar. i find it very frustrating. with one stick the computer is deciding what to do with your movements and it dosent always want to do what you think your telling it to
Unread 14-01-2004, 20:19
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
I second this! heh, I've used 2 sticks for tank style driving since 7th grade. I sincerly doubt you'll get me out of the habit.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 14-01-2004, 22:08
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Those are null wheels. They adjust the offset and are used to null the joystick. What we're looking for is a wheel that gives its own analogue output, not just adjusts another.
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 15-01-2004, 00:57
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Alas, the side wheel is gone
We do, however, have two more buttons built into the joystick that work. The button to the left of the omni-directional thingy is pN_sw_aux1, and the other one is pN_sw_aux2 (where N is obviously the port number).
Unread 15-01-2004, 08:33
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
I agree that the new joysticks are awkward to drive but they are nice as a secondary control. For the drive I'm going to switch back to the old joysticks! At least they fit your hand!
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 15-01-2004, 09:49
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
I don't particularly like the new joysticks. They feel flimsy and plasticy. The old joysticks, the ones we will be using this year, feel sturdier and generally more comfortable. Plus the whole 2-joystick drive for tank drive robots problem with the right handed joysticks, but that has been elaborated upon already.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 15-01-2004, 10:02
A few years ago we had a stick that was similar in design to the new ones but black and much sturdier. Unfortunately it broke when we took the robot somewhere to showcase it...
Unread 15-01-2004, 10:04
Aignam's Avatar
This Space For Sale
AKA: Anthony Mangia
Team Role: Scout
One of our last year's joysticks broke during an unfortunate carride to a demonstration. It was an interesting demonstration, using our duct taped krazy glued joystick, but thankfully another team lent us one to use for the day. We bought another joystick to replace it, though.
Unread 15-01-2004, 10:07
Yea, we would have bought a new one after that one broke (hit by car door) but it was post-season so we didn't think anything of it until it was too late to remember where it was from...
Unread 15-01-2004, 15:10
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Does anyone happen to have the model number/website for the joysticks. I havent had a chance to see them any I won't be able to get to them till Saturday.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 15-01-2004, 15:28
robolemur1236's Avatar
robolemur1236 robolemur1236 is offline
robolemur1236 can only hope to improve
i want the website too...
it has this weird AB swooshy logo on it and a model #, but besides that, nothing. If we get the website we can get a lefty joystick
besides, we can always just 'modify' the joystick if necessary
being requiring of an interesting team name/mascot/motto that is appropriately geeky and at the same time pleasing to the ear.
Vanilla Coke..good? bad? A. Leese Chit-Chat 41 07-01-2004 00:15
college counseling decides to help us... good or bad? AlbertW General Forum 4 16-05-2003 15:14
NYC Regional- Give me the good, bad, or ugly... Rich Wong Regional Competitions 23 28-03-2003 17:56
Chiaphua Motors: Good or Bad to 2002 Kit Of Parts? D.J. Fluck Motors 25 05-07-2002 16:40
good idea or bad? archiver 2001 4 23-06-2002 23:08
