Go to Post There's 2 things that are really hard in CS - naming things, cache invalidation, and off by one errors. - Andrew Schreiber [more]
Unread 14-01-2004, 20:27
Umm Errr...
Re: Pressure transducer
Originally Posted by NoRemorse
the TI pressure sensor, anyone know anything about it? can it messure vacuum? how sensitive is it? can i find specs online? thnx!
According to the pnumatics manual, its supposed to be a TI 5CP3-7, but as far as i can see no such part exists.
Here is the TI pressure transducer division website: http://www.ti.com/snc/products/sensors/ipt.htm
They r supposed to be 0-130 psi, 0-5v porportional output. Thats all i know.
1139 Alumni
Unread 14-01-2004, 23:43
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
from the looks of things it looks like the 67 CP model, which the site says has a 1.5% error rate, so at 130ps its ~1.8 psi error. I'd also suppose that when the compressor is on, then reading are innacurate, watch the gage when you power up to see why. I've tried 5cp3-7 and all varients their of, and I do find a few sites in japanise. I dont know what they're saying though. for ti, though, "CP3" is some type of input pin on a TMS370Cx36 8-BIT MICROCONTROLLER, maybe first confused the "transducer" with a electroinc componet of the transducer... or its a proprietary part #...
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Nason pressure switches JP_1163 Pneumatics 11 03-03-2003 23:03
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
