Go to Post Anyway, everyone, PLEASE READ THE MANUAL VERY CAREFULLY and ask around for the answers before going directly to FIRST. :) - AmyPrib [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 14-01-2004, 19:47
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
Exclamation Problem with 5/8 in. shaft in this years kit
For for those of you that have started building a drive system you may have noticed that the 5/8 in. shaft doesn't fit the 5/8 in. bore in the gears for the gearbox and the bearings very well. I had grabed some other 5/8 in. shaft we had around the shop and tried it with the componets and had a much better fit. Which leaves me to beleave that shaft included in the KOP is not really a shaft at all but a 5/8 in. axel with a key cut through it. For those of you that are lost a 5/8 in. axel when measured is 5/8 in. while a 5/8 in. shaft when measured is slightly less than 5/8 in.
I'm not shure if it was like this in any other of the KOP but it would be intresting to find out. I would like to find out who screwed that one up. For the sake of knowing the shaft is made of a polished steel that has resembling look to chrome. If you take any of the 5/8 in. bearings or gears and have a hard time putting them on the shaft, then I suggest that you go and purchase a real 5/8 in. shaft. The componets should slide on much easier without the need for a hammer.
Unread 14-01-2004, 20:22
Vince's Avatar
Vince Vince is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1994
Vince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond repute
Re: Problem with 5/8 in. shaft in this years kit
I found that you really have to file down any burs on the supplied shaft edges to make them fit in the bearings. Just running a file around the edges helps the fit quite a bit.
Unread 14-01-2004, 20:32
echos's Avatar
Jack of all trades
#1125
If its been polished how can it have any burs?
Unread 14-01-2004, 20:36
Vince's Avatar
Rookie Year: 1994
when you cut it down to size
Unread 14-01-2004, 20:56
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
That is the right size. It really is a pain in the but to get everything on especially with new shafts.
Unread 14-01-2004, 21:21
I think they are that tight for a reason - you REALLY dont want any slop in your gears on the shaft, the slightest bit of play will cause them to slam everytime you change direction, then the gears will get looser and looser over time.
something else you can try with the gears is to warm them up a bit, or to put the shaft in the freezer before you assemble it.
Should FIRST include Bosch Drill Motors in Next Years Kit of Parts mtaman02 Motors 9 05-07-2002 16:32
Need Help on Shaft Mounting... archiver 2001 3 23-06-2002 23:29
The key to this years problem ..... archiver 2001 5 23-06-2002 22:34
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
Parts file for this year's kit SiliconKnight Kit & Additional Hardware 1 12-01-2002 14:05
