Go to Post Karthik is afraid of the day he can't agasabapathy. - DesignComp [more]
Unread 13-01-2004, 02:11
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
PVC Wobbly in goal?
Can anyone who was at the Manchester kickoff tell me if the PVC tended to rise perpendicular from the ground, or did it have a lot of play? We made the field & goals according to spec, and the PVC is very loose in the holes. Left to itself it tips maybe 10 degrees off vertical.
For those building the field, I'd recommend that you buy materials based on the actual plan BOMs, not the BOM that FIRST provided before kickoff.
Eric.
Unread 13-01-2004, 02:18
codeoftherobot's Avatar
codeoftherobot codeoftherobot is offline
Safety General
FRC #1097
codeoftherobot has a spectacular aura aboutcodeoftherobot has a spectacular aura aboutcodeoftherobot has a spectacular aura about
Re: PVC Wobbly in goal?
I was thinking that it is intentionally loose for placement of balls and such. If you noticed at the kickoff that the PVC was loose which allowed for easier capping of the goals. We built ours according to spec but I don't think we had a 10 degree off vertical. Just a thought. I would recommend securing it by placing a stopper if it is too loose.
Sacramento Regional 2003 -Rookie All-Star Award
Silicon Valley Regional 2003 -Rookie All-Star Award
Sacramento Regional 2004 -Autodesk Visualization Award
Sacramento Regional 2004 -Regional Engineering Inspiration Award
Silicon Valley Regional 2004 -Johnson & Johnson Sportsmanship Award
Cal Games 2004 - Finalist (thank you 968 and 114!)
Sacramento Regional 2005 - #1 Seed Team Regional Finalist (with 254 and 114)
Sacramento Regional 2005 - Johnson and Johnson Team Sportsmanship Award
Unread 13-01-2004, 02:21
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
AS it says in the plans, the PVC should be dressed to fit. I guess you could wrap it or something?
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 13-01-2004, 07:44
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Yep, the PVC shouldn't be to loose, but still easy enough to take out.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-01-2004, 09:17
Doug Traster Doug Traster is offline
Engineer
#0829 (Warren Robotics)
Doug Traster is an unknown quantity at this point
That which is called "1-1/2" Schedule 40 PVC pipe" actually has an ID of 1.610" and an OD 1.900" (according to McMaster-Carr). The holes that are specified in the drawing are 1-7/8" which is 1.875" in decimal. This means that if everything were perfect, the PVC would not go into the holes at all. On the drawing for the mobile goal (http://www2.usfirst.org/2004comp/200...veableGoal.pdf ) the words "Dress to fit" refer to the holes in the wood. I think they intend that you ream the wood out until the too large PVC fits OK. I don't know why you are experiencing a 10 degree slant or even a little "wobble". Those poles ought to be skin tight. Confession: We have not actually built our goals yet (today, I hope), so maybe I'm missing something.
Unread 14-01-2004, 09:21
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
After much testing, we have found that the poles won't bend or move ON THEIR OWN. But balls in the goals, the big ball, and robots can somewhat bend the PVC. Not much, but a little.
Also, I would rebuild your goals. You shouldn't have that much lean to them.
Unread 14-01-2004, 16:18
RabidWombat's Avatar
RabidWombat RabidWombat is offline
Hydrophobic Marsupial
AKA: Ian Lenz
#0639 (Code Red Robotics)
RabidWombat is an unknown quantity at this point
It definitely looked like the pvc was wobbling/bending some. They probably planned it that way to make it easier to cap. Alot of people on our team didn't know that when we were watching the animation, so we thought the robot broke the goal when the pipes bent when it capped it.
Unread 14-01-2004, 23:55
EStokely's Avatar
EStokely EStokely is offline
AKA: Eric Stokely
FRC #0360 (Revolution)
EStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond repute
We just completed a small goal. The PVC is Very straight and upright.
However the first pass had us missing the lower hole (poor placement) with the PVC so there was a lot of lean as the PVC had nothing below it to keep it centered. Once that was fixed all was well.
That hole was tight though :-)
Eric Stokely
Team 360 The Revolution, past mentor of 258 The Sea Dawgs
Experience is what you get when you don't get what you want.
Unread 15-01-2004, 10:25
Alfred Thompson's Avatar
Alfred Thompson Alfred Thompson is offline
Adult troublemaker
FRC #0811
Alfred Thompson has a spectacular aura aboutAlfred Thompson has a spectacular aura about
Send a message via AIM to Alfred Thompson
The pipes in the goals at the Manchester kickoff seemed pretty tight in the holes when I tried them. In other words I pulled on them to see if they'd come right out and they didn't. It would have taken more effort then I wanted to spend to take them out.
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
