Go to Post Let me live in my delusional world where minibots never happened and the Tetrix kit doesn't exist. - Andrew Schreiber [more]
Unread 13-01-2004, 23:07
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Weight of fully inflated ball
I'm trying to calculate some torque, but my team is having trouble finding a scale we'd consider accurate for an object the weight of the ball. I tried to do some searching... I saw a post that refered to it as 2lb's, but I'm not sure if the person actually weighed it or if it was just an estimate. So, has anyone measured the weight of the fully-inflated ball on a device that could be considered accurate on 1-10 lb objects?
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 14-01-2004, 03:22
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Weight of fully inflated ball
We weighed the large 2x yellow ball today and got 3.6 lbs +/- .2 lbs. If you figure on 4 lbs you'd be safe. The 2 lbs seems a bit low. Anyone else confirm this? If all else use some triple beam balances from your schools science department (they usually hold up to 1.1 kg ~ 2.3 lbs), just balance the ball on two balances and add their readings up. Or take the ball to your local Mail Boxes Etc or Post office and have them wiegh it on their scales.
Unread 14-01-2004, 09:20
its a lot easier to weigh before you inflate it!
Unread 14-01-2004, 10:06
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
You'd have to weight the air too right?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-01-2004, 12:37
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
No, the weight of the air in the ball won't affect it as long as you are measuring it in air. If you were to measure it in a vaccuum, then yes, it would matter.
-Paul
Unread 14-01-2004, 13:03
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Weight of fully inflated ball
There will be a difference in weight, though it's most likely negligible.
Take for instance a cup. If you weigh it, it'll have the same weight as if you weigh it with a lid on top to trap the air.
However, let's say I was to take that cup, and really make it a cylinder, and fill it to 500 PSI... there's more mass of air in the system.
Because the ball is inflated, there will be a (slight) difference in weight.
10,000 points to the first person that can calculate the weight difference between an inflated and uninflated ball... (30" diameter, 30 PSI, assume 1/8" wall thickness)
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 14-01-2004, 17:18
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
We came up with 3.4lb agin +-.2lb so that seems accurate, ours was also inflated
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 14-01-2004, 20:42
Crusty Mentor
FRC #0097
Matt
well....
volume of a sphere = 4/3 * pi * r^3
30 inches = 0.762 meters
4/3 * pi * (0.762 / 2)^3 = .232 cubic meters = 232 liters
Now, considering 30 pounds per square inch = 2.0413 atm, if you rearrange the ideal gas law pV = nRT to solve for n,
n = pV/RT = [(2.0413 atm)(232 l)]/[(8.2057 * 10^-2 l*atm/(mol*K))((273+25) K)] = 19.4 moles of air
According to
this lab, the molar mass of air is about 29 g/mol, soooo
19.4 moles * 29 g/mol = 560 grams, or 1.23 pounds
That means that the air accounts for about 36% of what seems to be the measured mass of the inflated ball.
NOTE: For those of you who have read this far, I sincerely appologize, but I have a chem midterm next week.
[Edit]
BONUS POINTS to the first person to calculate how relativistic effects change the weight
Dan L
Team 97 Mentor
Unread 14-01-2004, 21:00
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
briholton is on a distinguished road
well....
According to
[Edit]
Yeah, but what was the name of that guy....hmmmm... archimedes or something ..... bouyant force..... "A body submerged in a fluid experiences a buoyant force equal to the weight of the displaced fluid." good thing your are studying for chemistry and not physics. Offhand, I think you need to reduce your calculation by about half since you've calculated on about 2 atmosphere and you need to take 1 off.
Unread 14-01-2004, 22:21
Crusty Mentor
FRC #0097
The ball is inflated at around 30 psi which is a pressure of about 2atm.
Dan L
Team 97 Mentor
Unread 15-01-2004, 01:15
Yeah, you're right, it would weight more. I was thinking that the air inside wasn't presurized.
-Paul
Unread 15-01-2004, 01:42
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Thumbs up Re: Weight of fully inflated ball
1.23 pounds
Let it be known that on this 15th day of January, 2004, SuperDanman is awarded the
Number Cruncher of the Day Award!
Woo hoo for Dan! He's getting some rep from me! Join in the fun!
Matt
Unread 15-01-2004, 19:59
briholton's Avatar
AKA: brian holton
Matt
HEY! he left out the bouyant force and thus did the calculation wrongly! Don't I get any credit for pointing that out? another award passes me by.... darn Nobel, happened with that one too!
Unread 15-01-2004, 21:11
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
And he just approximated
Should've used Dalton's law to solve for moles of the gas components (taking into account the composition of your local air supply) then used Van der Waals modified ideal-gas equation to calculate the partial weights of each gas then added them all together. The bouyant force's effect on the balls weight is easy to take into account if your assuming 2 ATM's pressure in the ball- just divide your final air weight by two (keeping in mind the air mass stays the same... for all those acceleration problems).
Don't forget molecules have volume and experience forces between eachother!
Of course even this is an approximation! You would need an even more complex model to take into account the molecular attaction between the differrent types of molecules in air.
Sorry about the extremely unecassary sarcasm there I got very (_very_) close to your answer by doing it my way. (good job)
Does anyone find it a bit concerning that we are trying to take the air's weight into account? A gust of wind or well placed vent could easily contribute that much force. I think we've determined the ball is in the 3 - 6 lb range, if I were designing a mechanism to manipulate the big ball I would probably assume 10 lbs.
(good luck on that test dan)
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 15-01-2004, 21:45
briholton's Avatar
AKA: brian holton
A factor of 2 is not an approximation!
Should've used Dalton's law to solve for moles of the gas components (taking into account the composition of your local air supply) then used Van der Waals modified ideal-gas equation to calculate the partial weights of each gas then added them all together. The bouyant force's effect on the balls weight force is easy to take into account if your assuming 2 ATM's pressure in the ball- just devide your final air weight by two (keeping in mind the air mass stays the same... for all those acceleration problems).
Does anyone find it a bit concerning that we are trying to take the air's weight of into account? A gust of wind or well placed vent could easily contribute that much force. I think we've determined the ball is in the 3 - 6 lb range, if I were designing a mechanism I would assume 10 lbs.
Greg
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
ball weight? Gadget470 OCCRA 4 02-10-2002 17:24
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
Ball Weight ? Anton Abaya Technical Discussion 3 15-01-2002 22:28
