Go to Post Changing lives as a key volunteer is not a right reserved for the "elite" among us anymore. - HurdFIRST [more]
Unread 15-01-2004, 10:34
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Re: Trouble with pwm outputs
Originally Posted by Just3D
You are correct. The & symbol denotes the address of a variable, passing this information to the printf function. Printf requires a pointer, which is why the & is needed.
So that's why printf hasn't worked for me the past 8 years, I should have tried adding an '&' and would have all been good
Please do NOT answer questions if you do not know the answer. Giving people an authoritative answer when you don't really know what you're talking about is bad and is one of the huge downfalls of CD.
printf does not require the address of the variable unless you want to print out the address. It takes the variable itself. Do not use an '&'.
int a;
a = 5;
printf("%d %d\n", a, &a);
will print
5 2293484
Notice that the first one printed the value of a and the second printed the address of a (address will vary).
Also, as gwross (someone you should always listen to) said, you need to cast your variables to an integer to get them to print correctly with this implementation of printf:
printf("%d\n", (int)a);
As for the digits between the % and the 'd', lpramo55 was right in saying the number controls the number of digits output. If you write a 3, it will display 3 digits, adding zeroes as necessary. This also works with decimal places.
Also not correct.
int a;
a = 5;
printf("%3d\n%03d\n", a, a);
will print out:
  5
005
The zeros will only be printed out if you have a '0' before the number.
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Hints For Rookie Programmers Noah Programming 30 20-02-2003 20:07
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
