Go to Post I, for one, am perfect and therefore make no mistakes. (Unless you count all the times that I completely screw up) - Molten [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 15-01-2004, 10:07
MechaJag MechaJag is offline
MechaJag is an unknown quantity at this point
Sprockets and Chain
Could someone please help me with a problem we are having? We need to order some more sprockets that are exactly the same as the ones we have. I've looked at the mscdirect.com site and it is to confusing. What exactly am I looking for? Also need help on what type of chain to get. I need another chain that is like the one in the kit. THanks for any help.
Unread 15-01-2004, 10:52
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Re: Sprockets and Chain
The chain is #35, also called 3/8" pitch. The sprockets are 3/8" pitch 45 tooth and 10 tooth, with 5/8" bores. This information can be found on page 9 of Section 6- The Kit from the manual.
Unread 15-01-2004, 11:03
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Sprockets and Chain
Alright, I'm assuming the "ones you already have" are the sprockets that came in the kit.
Sarah answered this well already.
Other notes:
  • Make sure you use the idler sprocket and keep that chain TIGHT
  • When ordering chain, make sure that you have lots of master links and half links.
  • Ideally, you should make sure that you have the center distances on your shafts such that you won't ever need half links. To do so, you should probably use a sprocket center distance calculator.
Oh look, I have one! (Sorry for the shameless plug of my own work...) It's attached.
Hope this helps,
Matt
File Type: xls Sprocket Center Distance Calculator.xls (17.0 KB, 160 views)
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 08-02-2004, 22:41
Alaina's Avatar
Alaina Alaina is offline
J = Pf - Po
FRC #0814 (Megaforce Squadron)
Alaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to behold
Send a message via AIM to Alaina
Yeah, where can one order more of that chain? I know what kind it is and everything but I can't find it. Not even at the website cited in the manual. Help please?
"It's cool to be a geek!" -- Dave Lavery
"It's all about the math." -- Mark Leon
Unread 08-02-2004, 22:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
www.mcmaster.com www.mscdirect.com www.smallparts.com www.SDP-SI.com
All of those have #35 chain.
Cory
2001-2004: Team 100
2006-Present: Team 254
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Nylon Roller Chain Sprockets Jim Smith Technical Discussion 6 20-01-2003 20:01
Chief Delphi sprockets archiver 2001 23 24-06-2002 01:46
sprockets Greg Needel Technical Discussion 0 23-04-2002 12:30
