Re: Belting
Is this similar to what you are looking for?
The orange belt on the center? This is our 2000 'bot but unfortunately I can't remember what the belt was called. I was just hoping this image would show the kind of belt you were looking for and maybe Andy or someone else who used it could chime in. ![]() |
Re: Belting
224 also used that same tubing on thier 2002 robot, you could try finding someone on thier team to answer what it is. http://www.geocities.com/firstpsga/home.htm is thier website.
From what I saw those worked amazingly well on the soccer balls. I would check with mcmaster www.mcmaster.com or check with msc. edit: Quickly looking around mcmaster I found these, part #'s 6567K32, 3044K195, there are many others in the round belts section of power transmission. I'm sure someone from a team who has used these before could give you the place and part number. There is also this interesting material that is all peiced together so you can get very nice connections in any length you want, # 2243K12 Last edited by Rob Colatutto : 15-01-2004 at 20:17. |
Re: Belting
Thanks this is really helpful.
| Warning to teams using a certain incline conveyor belting. | Patrick Wang | Technical Discussion | 3 | 12-03-2003 13:38 |
| Source for yellow ___ Belting | Travis Covington | Technical Discussion | 1 | 26-01-2003 20:11 |
| Experiences with Belting | Patrick Wang | Technical Discussion | 15 | 26-09-2002 20:26 |
| Chief Delphi: where'd you get that amazing conveyor belting? | archiver | 2001 | 1 | 24-06-2002 04:13 |
| Rubber Treads Anyone? | archiver | 2000 | 10 | 24-06-2002 00:29 |
