Go to Post You have to admit, Regionals are pretty strange places, albiet cool - Otaku [more]
Unread 15-01-2004, 20:25
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Re: Drill Motor Gear Specs?
Well the experiment has taken place, and with much success. While I agree that a press is a much safer bet, I had a very hard time fitting a plate between the pinion and the motor, so to the dremel I went. I first masking taped the ENTIRE motor, so that shavings would be reduced to a minimum. Instead of using a cutting wheel though, I used a grinding stone to grind away 2 semi-flat places of the gear without going all the way to the shaft. After this, I put the motor is a vice and tightened untill..crack went the pinion down one side. After this it popped right off with a piece of brass as a punch and a ball peen. I cannot be happier with the outcome and had no bad experience using the dremel to do this. Some teams that have a hard time trying to press the pinion off should look into this as a fast and easy alternative, in my opinion.
-Rc
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor specs Caitlyn691 Motors 34 17-01-2003 13:33
Specs for drill motor gearbox? archiver 2000 4 23-06-2002 22:36
Specs on Drill Motor Gear JoeJ Motors 3 07-02-2002 12:51
