Go to Post you don't need a fancy workshop to build a good robot, just determined people. - pacoliketaco [more]
Unread 15-01-2004, 21:03
MechaJag MechaJag is offline
MechaJag is an unknown quantity at this point
Gearing down motors
We're fairly new to the game of robotics and everything that goes along with it. One question we have is: Are the CIM motors a good motor to run your entire robot off of. We were planning on using the CIM motors this year instead of the drill motors. We had a ton of problems with the drill motors last year. Are we going to have to gear the CIM motors down to run two wheels off each motor? Will the CIM motor be efficient enough to pull two wheels? Any help would be greatly appreciated.
Unread 15-01-2004, 21:08
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
Re: Gearing down motors
You definitely need to gear them down. They spin at something like 4000 RPM's... way too fast for a drive train. Geared down appropriately, the CIM's will provide plenty of torque and speed.
This year, however, you may not need as much torque as you did in the past. The ease of using the drill motors is a strong argument to stick with them.
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 15-01-2004, 21:09
Jeremy Roberts's Avatar
Jeremy Roberts Jeremy Roberts is offline
Coach 4026
FRC #4026 (Global Dynamics)
Jeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant future
Send a message via AIM to Jeremy Roberts
Either the drills or the CIMs will be fine as long as they are geared down (we choose how fast we wanted to move and geared accordingly). We are also using the 2 CIMs to to drive our robot.
Jeremy Roberts
GeorgiaFIRST Planning Committee | Peachtree Regional
Georgia Tech RoboJackets FIRST Co-Founder
Engineer/Mentor 4026
Former teams: 132, 608, 832, 1002, 1848
Unread 15-01-2004, 21:45
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Actually we have already made our calculations for the gearing reduction and are prepared to order parts. The CIM motors are the choice for this years robot.
Guess we need to have a team meeting with EVERYONE attending.
Unread 15-01-2004, 22:06
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
My team drove our robot with the CIM motors and a custom 2-speed gearbox the last two years. It worked out pretty well. The main advantage they have over the drills, that I've seen, is that you can get into a pushing match, and the CIM's won't overheat nearly as fast as the drills will. That might not be a big concern this year, but it helped us the last 2 years. We never once had a CIM overheat and need to be cooled after a match.
Jeff Waegelin
Unread 15-01-2004, 22:07
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
CIMs will work well. Just keep in mind that many of your opponents will be using BOTH the CIMs and the Drills, or maybe CIMS and F-Ps to drive their 'bots.
Unread 15-01-2004, 23:28
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
drill motors are more powerful. I'd suggest stick with them (no need for gearbox, also, use the included tranny!)
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 16-01-2004, 01:04
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
You need about a 30 to 1 gear ratio to get a good drive of off the CIMs and then use the 2 to 1 gear box provided by first to come close to the drill's 40 to one and 2 to 1 gear box. The CIMs are hard to overheat
Faridodin "Fredi" Lajvardi KD7WKD
Unread 16-01-2004, 16:52
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
There are some a good discussions about the merits of shifting vs. multimotor systems on these fori.
Search for "shifting transmission" or "mutli motor drive"
Joe J.
Unread 17-01-2004, 01:21
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Well, if you look at the spec sheets, the motors actually have really close power. The upside for the drill is that it comes with a handy dandy gearbox that reduces the crazy speed of 19,670 to something less than that (haha yea, I've never used the drill gearbox on a transmission, so I wouldn't know off the top of my head). The great part about the CIM motor is that it delivers lots of power, is smaller than the drill and its gearbox, and runs at a pretty low speed. Its free load speed is 5346 rpm, and its top load is 2680-ish, so just do the math. Ex: You want to go 10 feet per second, on 6 inch wheels. 10ft/s x pi x diameter = rp/sec. For this example, it would be about 6.4 rotations per second, or 380 rpm, at the wheels. You've got a running speed of about 4800 rpm at the motor, so do the math. You need about a 12.5 to 1 gear reduction. Using that, figure out what gears to use, and throw them together with some aluminum plates, and you've got yourself a drive train. Yea... but put a little more time into the calculations than I did. The process becomes a bit more complicated when you have multi-motor transmission, because you haveto gear the motors together, and that gets ugly. But.. the CIM motors are very good motors to use on a dive train, so good luck.
Unread 17-01-2004, 01:27
Oh, and just something I had to calculate out of curiosity:
Direct drive from the CIM motor to a 7/16" diameter wheel, you'll get 10 ft/sec!!!
Unread 17-01-2004, 02:27
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
The CIM motors work great to drive alone. We did this one year and found them to be very smooth. The downside is that they are very fast.
To calculate how to gear them down, you need to do a few things. First, decide how fast you want to move and how much force it will take to do it. Then, take the distance around the robot wheel. Knowing this, you can calculate the required rpm of the wheel shaft. Take that speed and compare it to the CIM motor. It will ikelt be many times, so you will have to do a multi speed gear reduction. This will include possible coming out of the CIM with a large gear, then attacking the large gears shaft to small sproket. Then you would attack the small sprocket to the wheel shaft (most likely with a large sprocket on it).
If you have any questions, e-mail me at cdk@1stnetusa.com
Good luck from 696!!
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
