Go to Post That wheel appears to have been forged deep within the fires of Mount Awesome. - viking1902 [more]
Unread 12-01-2004, 18:40
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: If you would "pull-up"...
Originally Posted by Cory
It really depends how you're going to lift yourself. If you were making a winch of some sort, Id say the easiest would be the Van door, sinceit already has a decent amount of torque, which you could reduce with sprockets and chains. Im not going to go into anything else, because I dont want to give any of my ideas away
Cory
A caution about the Van Door motor... we made a winch with it in 2000, but we had to use two of them to get enough torque to do it.
Also, if you're using the Globe motors for anything, make absolutely sure there are NO SIDE LOADS on the Globes. They can't handle side loads, and will burn out very fast otherwise. We went through about 6 of them making a lock mechanism for our winch in 2000.
Jeff Waegelin
Unread 12-01-2004, 18:52
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
The team I was on in 2000 (Team 49) also used the 2 van door motors to lift our bot in 2000.
We were under the impression that worm drives cannot be backdriven so we were a little disapointed to see that when we turned the power off after lifting, our robot slowly settled back to the ramp. We ended up having to make a possitive clamping mechanism.
MattB
Unread 12-01-2004, 18:57
other ways? dont forget we are allowed to use springs - you could come up with a mechasim that is spring loaded - once you hook on the enegry is release and up we go!
or how about retractable wheels! dont lift your bot, raise your feet :c)
Unread 12-01-2004, 19:33
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
MattB
I can confirm that the Van door motor do back drive. Actually, it would make sense that if these motors are used in real van doors, it is designed to be back-drivable so that whoever get trapped when the van door closes will not be crushed by the force.
So, if you are using the van door motor to lift your bot, you may want to design a locking mechanism. That is exactly what we did at 2000 when we used them to power a big arm that lift the robot body off the ground. Otherwise it will slip back down.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 12-01-2004, 20:11
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Fisher Price motors, I believe, can handle the task.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 13-01-2004, 19:41
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
what we've got in the works for this year is a 2" bore pneumatic tube on a double solenoid. of course, its not neccisarily a motor, but it's what we're counting on.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 13-01-2004, 20:08
robo-gordo's Avatar
robo-gordo robo-gordo is offline
robo-gordo is an unknown quantity at this point
About the Van Door Motors:
They can be back-driven. It has nothing to do with internal clutches, or anything else. (The drill motors, however have anti-backlash pins).
You can open the vand-door motors covers up by prying off about 6 or 7 plastic tabs. Inside you will see a big plastic gear connected to a work gear. Take a large (>8") vise-grip, and attach it to the output shaft. If you turn the wrench, you will see the plastic gear inside backdrive the work gear. The fact that the gear is plastic and liberally coated with grease may have something to do with it.
For those of you who have had the van-door motor stay: perhaps you had your victor's in brake mode, which prevents a motor from spinning when a neutral signal is received.
Also, believe it or not, the Fisher-Price motors are more powerful than the van door's. Check the specs.
All I need is WD-40 to make things go, and duct tape to make them stop. (That and an infinite supply of 7/16 wrenches.)
Unread 13-01-2004, 20:23
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Originally Posted by Mr. Ivey
O.K. So far you guys have listed using the window motors, a pnumatic piston, and two globe motors. Now yes you could use any motor out of the box, as long as you gear it correctly, but besides the window motors, globe motors, and pnumatic motors. What is a quick way to move these bots upward. I'm almost thinking something like a track that the bot can run up that doesn't actually pull, but pushes against the track.
Ivey
You could use the Window Motor with a tape drive to push yourself up, but IIRC, the pushing force of the tape is only around 100lbs, so you would need a light robot. On the other hand, using the Window Motor with a tape to pull yourself up might not be a bad idea...
Zan Hecht
Unread 13-01-2004, 22:10
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Ivey
I bet pneumatics would be fastest.
We will probably use a van door/winch setup this year, though, as we have a design that makes getting the hook on the bar quite easy.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 15-01-2004, 21:57
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Tape measures ought to do nicely.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 15-01-2004, 22:15
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
I don't want to reiterate the idea of pneumatics too much, but it seems like some are talking just about the new motor we have available this year and the rest aren't clear.
My thought with pneumatics is that you can easily put up a stiff arm 9' tall (10 from the floor, 9 from the platform) and then on the end of it have a nice wide pneumatic piston with a clasp/hook/whatever on it. You can activate the raising with a telescope or some simple lighter pneumatics - then you can lift up in an instant with the other one on the end. I think this might be a good approach for rookies since my experince is that pneumatics tend not to go wrong as often as the rest of the stuff.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 16-01-2004, 21:24
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
We've trusted the CIMs for two years straight as drive motors, and they haven't let us down yet.
We're using a drill for getting ourselves off the ground, but that's all I'm saying right now
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Balancing archiver 2001 15 23-06-2002 23:51
