Go to Post As Alice once said: "Curiouser and curiouser!" - Mike Betts [more]
Unread 11-01-2004, 20:27
kvzrock kvzrock is offline
kvzrock is an unknown quantity at this point
Question How does the rotary actuator work?
What can it do and what does the 90 degree indicator mean?
thx
Unread 11-01-2004, 22:00
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: How does the rotary actuator work?
According to the 2004 Pneumatics Manual, the rotary actuator we have access to is limited to 90degrees of motion. It is rated at 0.166 in-lbs/PSI, so at 60PSI, that works out to 9.96 in-lbs of torque.
Unread 11-01-2004, 22:48
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
It is designed to let you use compressed air to make a rotary movement -
maybe twist an arm or bracket or something else. It can replace an electric motor and potentiometer / limit switch set up., but you are limited on the cabability (basically 0 or 90 degrees and nothing in between).
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 12-01-2004, 00:39
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Just from looking at it, I can guess (not certain) that there is a simple rack & pinion inside. The rack is pnuematically driven inside the cylinder, and the pinion is attached to the output thus making linear into rotary motion.
For this year, we are limited to 90 deg of rotation, but at our pnuematic workshop we were told there are limiting screws taht can be adjusted to let it turn up to 320 deg under internal limits only.
Unread 12-01-2004, 13:39
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
I think the main thing that anyone needs to keep in mind when they use them is that these are not motors. they canot complete a revolution, however thay can go from say tharting position, and turn 90 degrees. they might me usable at the end of an arm to close a grabber, since they are light.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 13-01-2004, 12:47
Fred Hord Fred Hord is offline
Fred Hord is on a distinguished road
thx
Apply pressure to one side and the shaft rotates 90 degrees. The tolerance is minus 0 plus 15 degrees so it may turn up to 105 degrees. Apply pressure to the opposite side and it rotates back. For more information go to pneumaticsfirst.org and download the Pneumatics manual.
Unread 15-01-2004, 22:05
Chateau Picard's Avatar
Chateau Picard Chateau Picard is offline
Team 1387 President
AKA: Devin M-C
#1387 (Robodorf GH3)
Chateau Picard is an unknown quantity at this point
Is it limited to on or off (0 or 90 degrees) or can you adjust it anywhere in between?
"All systems automated and ready. A chimpanzee and two trainees could run her."
"Thank you, Mr. Scott, I'll try not to take that personally."
-Scott and Kirk, on the Enterprise
Unread 15-01-2004, 22:09
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
The pneumatics manual says this:
"The rotational tolerance of the unit is 90 degrees –0 degrees +15
degrees. Exact angle adjustment should be made with external stops."
That sounds like to me that it is either 0 or 90 degrees.
Eric
Unread 15-01-2004, 22:26
Koci Koci is offline
#0624 (CRyptonite)
Koci is an unknown quantity at this point
You can always just gear it 4 to 1, and get an output to rotate 360 degrees, or any other gear ratio imaginable.
2001 Highest Ranking Rookie at Lone Star Regional
2002 Imagery Award at Lone Star Regional
2003 Delphi's Driving Tomorrow's Technology Award at Arizona Regional
2003 Delphi's Driving Tomorrow's Technology Award at Lone Star Regional
Unread 16-01-2004, 00:49
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Not true. Their are capability between 0 and 90 and extend and retracted. I'm working on a white paper to show how. We used the capabilities on our pneumatic lift last year.
Unread 26-01-2004, 22:32
Darksun Darksun is offline
Darksun is an unknown quantity at this point
I had a question about the rotary actuator... are we allowed to order a rotary actuator that moves beyond 90 degrees? I was hoping for one that could move 180 degrees. Or is there some legal way of adjusting the rotary actuator to move beyond just the 90 degree limit... if so, how? Thanks very much!
