Go to Post Our job as mentors isn't to teach them how to make a robot...It's to teach them that there is value in technology and being among the people who create it. - Andy A. [more]
Unread 16-01-2004, 00:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Removing Bosch Drill Pins - Cause of Failure?
Okay,
Last year we did not modify our bosch trannies from the way we received them. We used them in a four motor drive and never once did they fail. However, they would make aweful crunching noises every now and then, that I assume is the pins.
To make for a smoother driving experience (like running on only Chips), I was thinking we would remove the pins this year.
I read all the other posts and threads on this topic and have not found my exact question asked or answered before.
Is there a direct correlation between removing the pins and drill tranny failure?
I don't think removing the pins would be the source of the transmission problems but perhaps taking the gearbox apart would cause it to go back together differently or looser. Is this true?
I want those pins gone but I never want to have to open or replace the transmission after that.
Unread 16-01-2004, 00:15
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Removing Bosch Drill Pins - Cause of Failure?
we removed the pins from our trannsmissions without ever experiencing a single problem after a regional, nats, and 3 off-season comps. I don't know exactly how it was done, but that's because we made sure that the guy who did it knew a lot more about subtly tweaking transmisions than the rest of us did.
in short, do it, it won't hurt you as long as you make sure that you do it right and don't damage other parts of the motor/transmision in the process.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 16-01-2004, 02:18
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Cool Re: Removing Bosch Drill Pins - Cause of Failure?
Originally Posted by sanddrag
Okay,
At the bottom of the rule state below you find the following text i typed in italicsRule 5.8.4 The drills clutch housing contains 2 internal back drive preventer pins thats keep the motor shaft from being turned (back driven) by its ouput shaft. These pins may be removed allowing the motors to be back driven by the robots momentum in an un powered state. FIRST recommends that you remove these pins. Detalied instructions about doing so are available on our site.
Does this help???
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 16-01-2004, 02:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you apply enough force, you can cause those pins to fragment. When they do, you destroy the transmission. We have always removed them.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2004, 04:21
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
My team removed the drill pins last year, but an important thing to remember is to know how the drill motors go back together. We had some motor problems because of not putting it back together exactly as it was before. Just pay attention as you are taking it apart, and it will cause no problems.
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 16-01-2004, 05:06
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Okay,
From my experience, there is a correlation between not removing the pins and drill tranny failure. Removing the pins is very simple, you just turn the top 1/2 of the transmission and it comes apart one stage above the planetary gears. We destroyed a transmission last year by not removing our pins, and after that we removed every pin from the transmissions. Removing these pins help prevent transmission failure.
-Rc
Unread 16-01-2004, 06:39
andy's Avatar
andy andy is offline
Alumni
FRC #1139 (Gear Grinders)
Team Role: Student
andy is a jewel in the roughandy is a jewel in the roughandy is a jewel in the rough
Send a message via AIM to andy
If you need to put something back together exactly as it came apart, take digital pictures, ALOT of digital pictures.
Also, the drill motors are not that hard to put back together...just set aside about 30 mins per motor and take your time. I had no trouble putting one back together after it rolled off the table once we took it out of our kit. Spur gears were everywhere! Just remember to take you time putting it back together, and test it OFF the robot! Try to backdrive the gearbox, on or off the motor, with the pins removed you should be able to backdrive the gearbox. Be careful the first time you test with power apply power gently. When you test, you wan to have it running at free load. Good luck, if you're in the same neighborhood and need some help look us up, we would be happy to remove the pins and put it back together again.
Good luck
-Andy
Unread 16-01-2004, 08:42
Okay,
Many teams leave the pins in for one reason or another. In my experience more teams have been hurt by leaving the pins in place than not. Depending on many factors (like robot weight and speed and defensive strategies) when the locking pins click into place, all of the robot forces are now transferred to that one spot in the transmission. It is not designed to take that kind of force. The locking pins were designed into the drill/screwdriver to allow users to tighten/loosen screws without the need to pick up a different tool. When disassembling the transmission, go slow and watch how it comes apart. There was a complete instruction set with pictures on the CD site last year. I believe this is a Power point presentation on how to do the mod... http://www.chiefdelphi.com/forums/pa...le&paperid=150
The locking pins are very obvious, they are about 3/16" in diameter and about 1/4" long and fit at the end of the "dog bone" in the assembly close to the output shaft. When you reassemble the transmission you need to rotate the output shaft a little to get all the parts to mesh. The case only goes back together one way so you may want to mark it before you disassemble. This is a very simple mod and can be performed in a very few minutes.
Unread 16-01-2004, 08:48
I have to add - GUARD your drill motor gear boxes from the general student population on your team
Several times I have watched a student pick one up, say "hey whats this thing?" handle it like any person would lookin at something new and strange
and within seconds, the transmission is open and the gears are all over the:
A. table
B. floor
C. student
D. all of the above
and they only go back together one way (not obvious)
denfinately let students look at them if they want to - but first make sure you know how to put one back together -second issue the warning "be carefull - it comes apart really easily!"
Unread 16-01-2004, 14:39
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
with our experience last year, after we took out the pins, our clutch started slipping and wouldnt stop. We tried changing the clutch setting but that wasn't the problem. So we actually had to weld the clutch together to stop the slipping. The drill transmission kept falling apart after every match and we kept putting it back together. But after a while parts wore out on it and it just wouldn't work. So we got two new drill transmissions and left them alone. We never had any problems after that.
Unread 16-01-2004, 16:08
mtaman02's Avatar
if you need step by step directions i'll ask my friend to see if he can post them
Volunteer Resume:
Unread 17-01-2004, 04:34
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Okay,
From what I have seen and heard, there is the opposite. Unless you want to stay put when power is cut(like on a ramp), there isn't a reason to leave them in. So long as you put it back together properly, it should work just fine. If you havn't done it before, take 20 minutes to do it so you will see how it fits together. Its easier that way then picking things off the floor and trying to figure out what goes in first.
And wear a shirt that you don't mind if it becomes permanatly grease stained.
Wetzel
Unread 17-01-2004, 08:24
REVving up for a new season
FRC #2848 (All-sparks)
the clutch plate is in a completely different location from the pins (you don't need to go to that bottom layer of planets where the cluch is so i can't see any reason that THIS would have caused the problem. although it is possible that incorrect reassembling could have lead to the problem...for this reason i also recomend taking the gear boxes apart slowly and over a white piece of paper.
Unread 17-01-2004, 08:29
Ryan,
If you dissassembled the trans to take the pins out and the clutch wouldn't lock, you had reinserted the clutch plate upside down when you put the trans back together. This is a common mistake.
Unread 18-01-2004, 12:11
Mike Rozar's Avatar
Mike Rozar Mike Rozar is offline
FRC #0547 (F.E.A.R (Falcon Engineering And Robotics))
Mike Rozar is an unknown quantity at this point
Does anyone know where we can get some drawings for the output shaft and the other parts you have to make when you get rid of the the back drive pins???? Please share if you can.....
We have some people to help the students machine these but maybe not design them.
Can you buy them???
Please help....
Mike Rozar, Engineer & Mentor
Team F.E.A.R. 547
2001 VCU Rookie All Star
2001 National Rookie All Star
2002 KSC Delphi Driving Tomorrows Technolgy
2002 Newton Quarter Finalist
2003 St. Louis GM Industrial Design
2003 Archimedes Finalist (47, 201, 547)
2004 St. Louis Chairman's Award
2005 Gret Lakes Judges Award
2006 St. Louis Winner (547, 71, 537)
...and the journey continues
Bosch Drill Motor rmmlg Inventor 7 17-12-2003 14:33
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Bosch Drill Motor CAD Files Madison Inventor 10 09-12-2001 00:14
