Go to Post There can never be enough recognition of a job well done. We can never say enough Thank You's. We can never measure the impact that an inspirational teacher or mentor can make on a student because it's priceless. - KathieK [more]
Unread 14-01-2004, 20:26
Gabriel Gabriel is offline
#1409 (Fightin' Llamas)
Gabriel is just really niceGabriel is just really niceGabriel is just really niceGabriel is just really nice
Send a message via AIM to Gabriel
Insights from 2000?
I noticed that the 2000 game also featured a chin-up bar. I, and I'm sure many other rookie teams and probably some second and third year teams as well are very interested in learning more about how the game played out and what strategies/mechanisms were successful.
I've looked through the pictures from 2000 and noticed that many teams tried to lift themselves straight up from directly under the bar, was this significantly better than lifting from an angle?
I noticed that many teams used an extendable scissor-lift mechanism (sorry, my terminology is abysmal) like the one in the attached picture. Is that type of system easy to build and effective?
Obviously, the answer to the next question depends on the mechanism you're using, but about how much time did it take to maneuver into the right position, lock onto the goal and pull yourself up?
Once you attach yourself to the bar how difficult was it to detach from the bar? How much time did it take?
We would greatly appreciate any insights or lessons you learned in 2000 that might be helpful this year.
Thank you,
Gabriel
Team 1409
Unread 14-01-2004, 20:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Insights from 2000?
A scissor link mechanism will work, however, they are usually associated with having poor lateral stability. We used a scissorlink lift in 2000 to get the balls to the trough, and I can tell you, it swayed from side to side quite a bit. You can beef it up enough to avoid this, but it might be quite heavy.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 14-01-2004, 23:35
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
Gabriel,
In 2000 we used a fiberglass rod to engage our hook which was slightly larger in diameter than the hanging bar. As we drove under the bar the hook would engage the bar. We used nylon cord to pull our 129 lb robot off the ground about six inches. It took about 12 seconds to get six inches off the ground. I hope this helps.
Ken Loyd
Team 64
PS It worked well enough to allow us to make it to the semi-finals that year.
Unread 15-01-2004, 09:46
Thanks guys.
Do you think that getting up that 6" barrier and hooking on to the bar is a little too ambitious for a rookie team? We have a lot of enthusiasm, but limited time and experience.
Unread 15-01-2004, 09:58
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
A rookie team with limited experience should first concentrate on driving. Get a drivetrain that works so well you never have to worry about it failing in a match. Over the years I've seen rookies that simply can't drive well enough to be effective in the match, Wildstang included . It does no good to be able to hang if it takes you the whole match to get there, but a robot that can simply drive around well can push balls to the HP and play defense, both of which will help your alliance. Once you have a solid drivetrain then you can concentrate on other mechanisms - ball collector, big ball scorer, hanging device. Be thinking about and designing these parts, but don't sacrifice a driving base for them.
Unread 15-01-2004, 10:04
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
Thanks guys.
Do not limit yourselves on ideas or ambition...be realistic about the design build time. If you keep to a schedule - you can be a little ambitious. The mechanics of 9ft+ reach will be a big challenge, and the 6" step also difficult. Look at systems that exist in the world already for ideas...ambulance guerneys, tanks, and similar devices. Try to get in touch with some of the veteran teams near you, maybe they have videos from 2000, 2001 that they would share with you. Good Luck!
I Absolutely agree with Mike...
Unread 15-01-2004, 10:38
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Smile Re: Insights from 2000?
The biggest problem I saw at the 2000 competitions is robots that don't have enough power to lift them off the ground. They would latch onto the bar, begin pulling up and either not make it off the ground, or would lift off the ground only to have the motor's thermal shutdown activate and they would slowly sink back down to the floor.
BIG MOE (365) was designed in such a way that it didn't have to lift up the entire 130lbs of the robot, only the drive chassis. All of the electronics and the air tank (no compressor in 2000) were mounted on the arm, and the drive chassis was basically only a frame to support the arm and a simple drive. When we hung on the bar (the hangers are painted green just behind the basket in the image below), we just used the arm, powered by 2 fisher price motors and a gear box (not easily seen in this picture), to pick up our drive chassis. Instead of doing a chin-up, BIG MOE just grabbed onto the bar and picked up its feet. This was our rookie year, and it was a lot of fun to do.
Oh yeah.. GO MOE! ! !!! !!!! !!
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 15-01-2004, 21:09
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
I, personally, like an arm for lifting yourself up.
RAGE did it in 2000. There are two pictures attched to illustrate.
The huge arm (excluding the basket) extended to almost double it length, and had a hook on the back. It allowed us to reach the bar from the flat field surface. We could reach over other bots and pull ourselves up.
[edit]The extending was powered by the window motor using a tape drive. Once the power went off, it locked into place.[/edit]
ID:	1713  Click image for larger version
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 15-01-2004, 22:34
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
In 2000 TJ went and charged the ramp with a locking device that once it hooked on the bar it was impossible to release. We used telescoping arms to get the necessary height. As a driver we dedicated the last 30 seconds of the match to hanging it took probably maybe less than 10 seconds to hang with our mechanism but between battling and manuevering your way up there for position needs to be accounted for. Hope this helps a bit.
119=190 right?????
Unread 15-01-2004, 22:37
Kevin Casper Kevin Casper is offline
#0171 (Hardcore Engineers)
Kevin Casper is an unknown quantity at this point
In 2000 we did our best not to let anyone on the bar. We were effective too. We won every match in which our power didn't shutdown for some reason or another. We won 2/3 of the matches.
Kevin Casper
Unread 15-01-2004, 23:56
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
i think assuming that it is necessary to be on top of the 6" step in order to grab the bar is a mistake. If you can make your arm go another foot, then you save yourself the trouble of figuring out a way of climbing of the platform.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 16-01-2004, 00:27
Remember you will be at an angle. It will be more like an extra foot and a half.
Kevin Casper
Unread 16-01-2004, 00:30
Solace's Avatar
AKA: Jake
perhaps, but that depends entirely on how you construct your arm.
...What is a man,
Jake
Team Paragon #571
Unread 16-01-2004, 02:43
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
back in 2000 the old 2 school team Team 371 constructed a robot with a basket / bucket device. so that the HP may throw the balls in there and have the robot deliver it by un latching the bottom of the basket. when it came time for hanging under the basket there were i guess latches or hooks in which where the basket can be raised and then lowered onto the bar. I can't find a decent picture of the robot in delphis gallery however i did find one in ROBERTA in her starting position
Team 371 2000 J&J Mid-Atlantic Regional
If I can find an old picture i'll post it!
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
RAMPAGE 2000! archiver 2000 0 24-06-2002 00:26
Rumble 2000 webpage is up archiver 2000 0 23-06-2002 23:26
2000 WMRC Team List Now Available! archiver 2000 0 23-06-2002 22:55
Scaling Values in the Control Program archiver 2000 15 23-06-2002 22:24
2000 not a new Millenium archiver 2000 7 23-06-2002 22:17
