Go to Post "The hardest part about building the robot is figuring out what to build..." - Jeff Waegelin [more]
Unread 15-01-2004, 14:44
Gabriel Gabriel is offline
#1409 (Fightin' Llamas)
Gabriel is just really niceGabriel is just really niceGabriel is just really niceGabriel is just really nice
Send a message via AIM to Gabriel
Playing Field Carpet
We are a rookie team looking to build as much of the playing field as possible. We have gotten local businesses to generously donate a lot of the lumber and PVC piping but we are running into problems with the carpet. We've been allowed to build the playing field in a college gym, but because the gym will be used for other things we will have to set up and remove the field every few days. I know that traction on a carpet is very different from traction on a floor so we will probably want to carpet as much as possible. Unfortunately carpet is very expensive. A local carpet store has offered us a $5/sq. yard price, which seems to be very good, but the carpet is basically felt with a latex-like backing. Will this be okay or will the robot tear it up? What carpet does FIRST use at the competitions?
Thanks,
Gabriel
Team 1409
Unread 15-01-2004, 14:50
Re: Playing Field Carpet
funny you should ask!
I was at Home Depot this morning, and happened to find two reminants of the type of carpet first uses. Its really inexpensive stuff, normally $4/sq yd at Home Depot
there should be official manufacturer and name/type in the field construction documents
the two pieces I got this morning were 12x20 feet, enough to make (almost) half the playfield - and they were marked down to $44 each - less than half price
so I got enough for half a field for $88
good thing is this stuff will last your team for a few years
Unread 15-01-2004, 15:01
Thank you!
Could you please tell me more specifically where the information on the carpet type/manufacturer is? I checked the field layout documents and couldn't find it.
Last edited by Gabriel : 15-01-2004 at 15:02. Reason: Fixed a really bad grammatical error
Unread 15-01-2004, 15:06
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Talking Re: Playing Field Carpet
well me and my team have been with first for 3 years (2001-2003) and there carpets have always been the same standard carpet not to fancy or anything just the kind of carpet ud find in businesses or schools or libraries or goverment buildings , probably not like the stuff you got at home(assuming u have some carpeting) Home depots a good bet if your Buying it on your own but then again there always the chance for a large donation from a local or maybe not so local Carpet venues
While i was writing this i got an idea and i found the contact info and site for the official FIRST Carpeting
S.S. Mills, Inc.
PO Box 1568
Dalton, GA 30722
Phone: 800-241-4013
Fax: 706-277-3677
Web: http://www.ssmills.com
thats from the Docs and Updates of Last year and i believe they would still be the same for this year
Answers! Answers! Answers!
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 15-01-2004, 15:32
Okay the phone number for S.S. Mills has changed. It is now 1-800-363-9061 The exact carpet FIRST purchased is Seqouia 20, it comes at $4.08 a square yard for over 100ft and $5.08 a square yrd for under 100 square feet. The rolls are 15 ft wide and the carpet will be delivered in 7-10 days.
Unread 15-01-2004, 15:58
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Also remember that you really don't have to go for asthetics on this one. If you can find the same carpet cheaper in a less-popular color, go for it.
Good luck!
-Jessica B
Unread 15-01-2004, 22:57
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
Also carpet installers that do lots of corporate work usually have large chunks of carpet they throw away. I would suggest instead of asking carpet resellers ask companies that do installation if they have any large chunks they dont need. The carpet first uses is cheap bulk stuff they use for cube farms and the like. If they dont have any new scraps, ask them if they are removing used carpet that you could take (doesnt have to be pretty to work).
Retired member of Team 108
Unread 16-01-2004, 02:51
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
you could also ask fellow teams that have been around that are located by you. they may have some excess playing carpet that they don't use given to them by the regionals coordinators / national coordinators
you have alot of choices go to the carpet installers to see if they have any they would be willing to donate (SPONSORSHIP)
you could go to home depot and buy the amount needed
or you can ask a local team located by u if they have an extra piece to share with you or if you can go to where they're at and use there playing field.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 16-01-2004, 08:56
This is where we find out how dedicated you are to your team - whether you are SERIOUS about FIRST or not.
Wife comes home, goes down stairs, comes up from basement with puzzled look!
Wife: Honey? what happened to the carpet in the basement?
Husband: Uh Ummmmmmm........!
Wife: what happened? did the basement flood? did something get spilled on it?
Husband: Err Ummmmmmm...
Wife [eyes bugging out] WHERES THE CARPET?!!!!!!!!
Unread 16-01-2004, 16:18
mtaman02's Avatar
no u didn't did u lol di u acvtually remove the carpet from the basemnt for ure team to do d\field practice lol she must have been pretty upset hehe : )
Volunteer Resume:
Can we use tape if it contacts the playing field? archiver 2001 1 24-06-2002 01:01
Looking for full playing field archiver 2001 1 24-06-2002 00:13
playing field updates? archiver 2001 0 23-06-2002 23:03
Many inexpensive playing fields archiver 1999 5 23-06-2002 22:57
3D Playing Field Available archiver 2001 5 23-06-2002 22:48
