Go to Post there is no such thing as too many offseason competitions. - Berserker [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2004, 16:03
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
Looking for Back up Battery?
Just finished checking in Kit. Could not find IFI Back up battery pack. Is IFI or FIRST shipping them out separtately? Did not see them on the check in list either.
Racing is an incurable addiction!!
Unread 10-01-2004, 17:08
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
Re: Looking for Back up Battery?
We did not have the battery either!! I don't know if anyone else has them or not.
Mike Rush - Engineer/Mentor
Perpetual Recursion (4154)
Arizona Community Team (1492)
2004 AZ Regional Woody Flower's Award
Basha High School & Intel (1456)
Gila Monsters (64)
Awards!?! Too many to list...
Unread 10-01-2004, 17:22
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
I believe that they are the same as the EDU battery (CHECK BEFORE ATTACHING) so I believe that they may just expect teams to use their EDU battery for the backup battery....
If the batteries are the same (I believe they are) you can purchase them at Innovation First.
-Grg The Great
Unread 10-01-2004, 20:04
m0rph3us's Avatar
m0rph3us m0rph3us is offline
AKA: Andre
#0293 (Spike)
m0rph3us will become famous soon enough
Send a message via ICQ to m0rph3us Send a message via AIM to m0rph3us Send a message via MSN to m0rph3us Send a message via Yahoo to m0rph3us
Yeah, it's not in the list of parts either so I guess we are supposed to use the one from the EduRobot. But they should have definetly been more clear on it.
Andre
Team S.P.I.K.E.293
Unread 10-01-2004, 21:33
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Page 5 of section 5 R39
Page 21 of section 5.8.7.2
I know it was in there more times then that.
Read the manual
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 10-01-2004, 23:56
the fabricator the fabricator is offline
Junior Member
the fabricator can only hope to improve
i dont think the beta bot batterie will have enough power for the whole bot, i mean just for the edubot ours only lasted half hour, the betabot batterie would be totally useless
Unread 11-01-2004, 00:01
I believe that the the back-up is just for those last seconds of a match.... im sure you have had it happen to you before where your battery dies as you go up the ramp or whatever you are doing in the last 15 sec.
-Greg The Great
Unread 11-01-2004, 00:26
Gabriel Gabriel is offline
#1409 (Fightin' Llamas)
Gabriel is just really niceGabriel is just really niceGabriel is just really niceGabriel is just really nice
Send a message via AIM to Gabriel
They announced at the rookie workshop that the backup battery is to be taken from the EDUbot kit. Also, the battery is to power the controller and nothing else. I'm not really sure what the point is except to tell you that the main battery is dead and the robot is otherwise OK. This means that we will have to manually hit the reset on the robot controller to turn it off, if you just shut the battery off the controller will stay on and drain the backup.
Currently: Team Leader - 1409
2001-2003 Founding Member Team 782
2003: New England Regional Winners
2003: New England Regional Xerox Creativity Award
2003: Newton Div. Semi-finalists
2000-2001: Team 508
Unread 11-01-2004, 00:30
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
In past years, when a robots systems draw too much current, the main system voltage dipped. Under certain circumstances, when the system voltage dipped below the controllers minimum functional voltage, the controller would stop working, and when it regained voltage, it would be completely reset. With this backup battery, the controller should never reset because of a loss or dip in main system voltage. The 7.2V battery is not meant to power any systems except for the controller alone, at all.
Unread 11-01-2004, 11:16
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
FotoPlasma is right, the backup battery is used to prevent resets of the program/OI. It is the 7.2V battery supplied with the EDU kit. You are to connect the battery directly to the connecter on the RC and nothing else! When you shut down your robot (or the power fails) the backup will hold voltage to the controller for 3.5 minutes just in case of a problem; in this fashion the controller will never reset unless you want it to.
To shut down the system immediately (for instance after a match) you must first cut power from the 12V, and then hit the reset switch. Without power to the main V+ connecter the controller will not start, hence using the reset switch to shut it down.
Our team's problem is that we never received our EDU kit!! We do not even have our backup battery! I guess we may need to purchase one from InnovationFirst... Anyone else have that problem?
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 16-01-2004, 11:57
Bob Steele's Avatar
AKA: Bob Steele
In Manchester at the clinics I believe we were told that teams could use ANY 7.2 Volt NiCad battery for this purpose. Before you purchase one and have it sent all the way from Texas (Innovation FIRST) Check and see if this is correct and look at a local hobby store. We also participate in BEST robotics and we use 7.2 batteries to power those (smaller) robots so we have a bunch of these around.
Another issue was recharging these batteries. The controller will NOT recharge these batteries while hooked up so they have to be recharged OFF the robot.
thanks
Unread 16-01-2004, 12:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If using an RC Car battery pack I recommend this charger. http://www.hobbypeople.net/gallery/350360.asp
Just whatever you get make sure it has a charge rate of about 4-5 amps and more importantly it is classified as a "Peak" charger.
Tower Hobbies has some Duratrax ones that are nice but they cost a little more.
Weigh in with or without battery Joe Clohessy Rules/Strategy 33 21-09-2003 20:31
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
