Go to Post Thanks, that clears things up a lot, and should probably have been obvious. - Branden Ghena [more]
Unread 16-01-2004, 13:39
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR sensors
Originally Posted by dmellich
Ok, we found the "hardware" for the IR sensor. However, we're not sure about the mounting board shown on the instructions. Is it the one that is in the padded envelope? If so, do we cut it down to a smaller size? Any help is much appreciated.
I think the piece of vectorboard is used to make the beacon (make sure you read the thread about the schematic error before you build this). The sensors are meant to be directly soldered to the end of a PWM cable or inserted into a connector that you build (this is what I did).
-Kevin
Kevin Watson
http://kevin.org
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
