Go to Post You know you're addicted to FIRST when...you realize that Dean IS changing society with FIRST and you love the fact that you are helping. - EStokely [more]
Unread 15-01-2004, 01:42
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: Current Sensor
Originally Posted by Garrix
If you look at the Robot Power Distribution diagram, you'll see the the negative wires running from the motors are routed through the large holes in the sensors.
Positive, actually, but that's irrelevant because the Victor speed controllers can reverse the polarity of their output in order to run the motor in reverse. In the datasheet for the chip, you'll find that it outputs 2.5V (the middle of the range) at 0Amps, and goes both positive and negative from there, 5V being some full Amperage forwards, and 0V being some full Amperage backwards.
Unread 15-01-2004, 01:50
Garrix's Avatar
Garrix Garrix is offline
Soldering Freak
#0840 (ART)
Garrix is an unknown quantity at this point
Send a message via AIM to Garrix
Re: Current Sensor
Actually you don't need to solder the 10 AWG wires into the holes. You can solder the 10 AWG wire to a large circular connector, and then you can bolt on the lead. I would suggest using a paper washer on the bottom before you screw the nut on. This is easier than soldering the wires in directly, and you can remove the current sensor more easily.
--Darn the robot is too heavy... take 10 pounds off the programming!
--I Eat Flux
--Arsenic, it does a body good.
Unread 15-01-2004, 11:27
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: Current Sensor
Why a paper washer? The object is to make a connection with the board, not insulate from it.
Unread 15-01-2004, 15:06
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: Current Sensor
Yeah I was mounting a new motherboard today and the places in the PCB where the screws went had the same ring of metal around them as on the sensor PCB.
But the soldering worked pretty well and with the connectors on the ends of the wires it makes it easy to add/remove from the circuit.
Unread 15-01-2004, 21:13
Garrix's Avatar
Soldering Freak
#0840 (ART)
Re: Current Sensor
You connect the ring terminal to the board, metal to metal, and before you put the nut on, you put on a paper washer, then you put the nut on.
Remember when soldering to add a heat sync to the sensor so you do not damage it. I know that FIRST has suggested using a small piece of aluminum, but I found that I got better results using an alligator clip on the pins that I was going to solder. Also if you mess up and fill a hole with solder, and you still need to put a pin in it, just simply touch your iron to the solder until it turns liquid, and use a high pressure spray of some sort (air or endust) and the entire area is clean; just make sure that noone is opposite of you when doing this cause noone likes being sprayed with hot solder. Wicking could also work to clear out the holes, but it would take longer, and is not nearly as cool
Another note of advice, always solder from the bottom of the circuit board where the pins are, and if your solder job is good, it will be shiny, and if it is dull you gotta redo the joint cause you got a cold connection.
--I Eat Flux
Unread 16-01-2004, 09:14
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Current Sensor
I would reccomend a solder sucker or a solder wick. Those tools are very cheap and are a lot safer than an air blast. The alligator clips do work since I used them in my electronics class to solder items. Also, a tool with adjustable alligator clips to hold your project comes in handy.
Unread 16-01-2004, 10:57
Re: Current Sensor
Garrix,
Just tapping the circuit board on the bench after you heat up the pad works fairly well also. But a better hint is to solder the #10 wires to the board before you add the sensor, that way you don't have to worry about heatsinking the sensor leads.
Unread 16-01-2004, 16:10
_GP_'s Avatar
_GP_ _GP_ is offline
AKA: Geoff P
#1277 (Crusaders)
Team Role: Student
_GP_ will become famous soon enough
Re: Current Sensor
so is there a posted version of the assembly instructions?
Unread 16-01-2004, 17:22
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Current Sensor
It's now at http://www2.usfirst.org/2004comp/Spe...ent_Sensor.pdf
Unread 17-01-2004, 19:22
Eugene Eugene is offline
#0321 (Lancers)
Eugene is on a distinguished road
Send a message via AIM to Eugene
Re: Current Sensor
Is it possible to order the complete kit from Allegro? If not, where can I get the PCB and the capacitor?
Thanks!
Eugene
Unread 19-01-2004, 01:01
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Re: Current Sensor
Originally Posted by Jay Lundy
(tripping breakers has always been a problem with us).
Can you post a picture of the finished product. We will be building ours tommorrow night.
Thanks,
Phil
Unread 19-01-2004, 12:11
lpramo55's Avatar
lpramo55 lpramo55 is offline
#0353 (POBOTS)
lpramo55 is an unknown quantity at this point
Send a message via AIM to lpramo55 Send a message via MSN to lpramo55 Send a message via Yahoo to lpramo55
Re: Current Sensor
Originally Posted by ToMMan b182
<--- i never really got this smiley
thats a lego head
Unread 23-01-2004, 01:45
Vladimir Vladimir is offline
the Impaler
#1064 (Wild Beast)
Vladimir is an unknown quantity at this point
Send a message via ICQ to Vladimir Send a message via AIM to Vladimir Send a message via Yahoo to Vladimir
Re: Current Sensor
I believe I have the current sensor wired up properly but the controller reads a number around 867 and never moves from that, no matter how much current I pass through it. I'm sure the PWM cable to the RC is aligned correctly. I tested the analog inputs with another device and they work fine (0-1023).. if I disconnect it the value floats around as it should, connect it, 867. Any ideas? Is it defective? I heatsunk it while soldering to make sure it wasn't damaged.
B.R.E.W. (Better Robots Engineered Wisely)
Unread 23-01-2004, 02:19
Re: Current Sensor
First of all use a multimeter to make sure the ends of your wire are actually connected to the big leads (just to make sure). Also make sure the big leads aren't shorted together somehow, thus bypassing the sensor alltogether.
Then try using the multimeter to read the voltage between the output pin and the ground pin as you pass current through the big leads. If your voltage changes but your input doesn't you have a problem somewhere besides the sensor itself.
That's all I can think of right now.
Unread 23-01-2004, 12:02
the Impaler
#1064 (Wild Beast)
Re: Current Sensor
I already checked to make sure all the connections were made properly (end of PWM cable pins to the pins on the chip, big leads to the big leads on the chip), I did not check resistance across the big leads, I will do that today. What should it be? I know it has to be very low because it is an ammeter...
Reflective tape sensor? scitobor 617 Electrical 2 19-11-2003 08:51
Current Monitoring system questions PyroPhin Technical Discussion 44 17-02-2003 15:34
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
What else do we want? archiver 2000 63 23-06-2002 23:19
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
