Go to Post Downsides: it's highly toxic and recognized as a carcinogen in CA. Upsides: Basically everything else - lethc [more]
Unread 16-01-2004, 13:36
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Probably a basic question, but....
Ok, I've never known what this code actually does:
PHP Code:
/**  example only **/
int hi 0;
   return
hi 0 0
Could someone explain that to me please?
My books don't have any explination (sp?) on that.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 16-01-2004, 13:56
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: Probably a basic question, but....
PHP Code:
int hi 0;
   return
hi 0 0
The ? : is called the ternary operator. It's a more compact way of doing if statements. The format is:
conditional statement ? statement executed if true : statement executed if false;
I'm assuming that extra 0 stuck in there after hi is a typo?
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
are you sure it's not
int hi = 0;
return hi ? 1 : 0;
what i've just written is equivalent to this:
int hi = 0;
if(hi) return 1;
else return 0;
basically, the code
a ? b : c;
means "replace this with b is a is true, otherwise, replace this with c"
so you could use
var1 += (x>2 ? 4 : 1);
to increment var1 by 4 if x is greater than 2, but only by 1 if x is less than or equal to 2.
it's more than just a compact way of doing if statements, as i've illustrated - you can't embed a if statement in an expression, whereas you can embed the ternary operator.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 16-01-2004, 14:01
AKA: Eric Hansen
Yea, I was typing kinda/pretty fast then.
  	int hi = 0;
 return hi ? 1 : 0;
  	int hi = 0;
 if(hi) return 1;
 else return 0;
basically, the code
 	a ? b : c;
Thanks, that really clears it up (also thanks to you Jay ).
It might make if-case statements more easier
Y!: synsoflife
Unread 16-01-2004, 18:59
AKA: Eric Hansen
Here's another question....
I was searching through the default code for the tracking. I opened up "ifi_default.h", and saw that in the struct's, it'd have like: "unsigned int pie:1;"
My question now is, does the colon take the place of the equal sign?
Y!: synsoflife
Unread 16-01-2004, 20:07
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
The :1 indicates pie occupies a single bit.
Unread 16-01-2004, 20:51
AKA: Eric Hansen
Thank you for clearing that up for me.
I just that it was another way to assign a variable.
Y!: synsoflife
Unread 17-01-2004, 01:04
Computer Guy
AKA: Dav
it basically allows you to save space - you could use each of the 16 bits of an int to store a different 1/0 value, approximating a set of 16 booleans
A question about control system options computhief263 Control System 7 04-02-2004 14:46
Very Basic Programming Question kewlkid382 Chit-Chat 5 18-01-2003 11:11
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
Question about Basic Stamp miketwalker Programming 3 14-01-2002 13:10
Have a question about the Basic Stamp Chip Boards wes16zeus Programming 3 06-12-2001 08:25
