Go to Post I think I'm going to need a 12 step program to help cure me from my Cryptic Dave Lavery Chief Delphi Post Analyzation Disorder I got goin' on here. - Elgin Clock [more]
Unread 14-01-2004, 01:02
iCHiMaHoCV iCHiMaHoCV is offline
iCHiMaHoCV is an unknown quantity at this point
Re: Leaning against vertical bar
Because the manual DOES say that the Robot is considered hanging ONLY if it is DIRECTLY supported by the horizontal bar and because Dean did say something like, "Lets not interpret this like lawyers..." I should think that you cannot touch the vertical bars. However, if your bot is touching the vertical bar, but it could be supporting itself just fine without touchign the vertical bar then it should be legal because it isn't relying on the vertical pole to lift itself. Thats just my interpretation of the rule.
Unread 14-01-2004, 02:18
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I have to throw something else in the blender now!
What do you think of the legallity of using the side vertical posts as leverage for just pulling your self up onto the step, but not using it to hang from?
Kind of like a kid climbing one of those big playground slides, you use the side rails of the steps (almost vertical) to achieve a "boost" to pull your self on to the platform(s) but not grabbing the vert pipes during the actual hanging process.
What do you all think of that?
Unread 14-01-2004, 09:10
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Come on folks, do you not think FIRST intended to allow 4 robots to hang at once? Don't you think Dean and Woodie want to see this happen in some rounds - how exciting is it when at the last few seconds all robots get on the bar?
Assuming that, and since the horizontal bar space is less than 8 feet, is it really likely that 4 robots can hang from the bar without at least one touching or leaning against the vertical post?
I am willing to bet that they will not call a penalty if a robot is hanging and is leaning against the vertical post.
On the other hand, they want to protect that mechanisim that raises and lowers the bar. So, they do not allow attaching to the vertical posts. And they will not likely allow you to use it as leverage to climb to the horizontal bar.
That's what my common sense tells me.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 14-01-2004, 11:25
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Originally Posted by 353Pobots
Are you allowed to lean against the vetical bars while hanging off of the horizontal bar? I know the manual says you are not allowed to attach yourself to the bar, but says nothing about leaning or touching it.
We have an answer from FIRST. According to their Q & A System:
Q: Please define what is meant by "Attaching". It is not clear if we are allowed to touch, or lean against the vertical supports as long as we are hanging from the horizontal bar.
A: Refer to the definition of "supported." Incidental contact with the vertical poles of the Pull-up structure is allowed.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 14-01-2004, 11:55
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
I'm glad that this has finally been resolved. What I now want to know is why would somebody ask:
From the Q&A system (search for "Vertical"): what do you mean by "not directly supporting a vertical component of the load"?
Isn't that an obvious answer? Simple physics, my friends...
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 16-01-2004, 22:37
Zach Purser's Avatar
Zach Purser Zach Purser is offline
AKA: Gumby
FRC #0435 (Robodogs)
Zach Purser is a jewel in the roughZach Purser is a jewel in the roughZach Purser is a jewel in the rough
Send a message via AIM to Zach Purser
I'm a little slow so can someone explain to me, if you are hanging on the horizontal bar from the opposite side of the vertical bar and your gripping mechanism is in the corner where the two bars meet, is this legal or are you using the vertical bar?
Attempt at a drawing:
..........|x____
..robot.|
Unread 16-01-2004, 23:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
A little off topic, but unless youve asked FIRST a question via the Q&A Forums, or you read a response on there, or it's a clearcut answer (In this case, it obviously is not) why throw out the "In my opinion, I think, We have decided, etc" Everyone of those statements makes it very clear that you dont know the answer.
Why waste space if you just want to contribute your opinion?
It took 18 replies to get an answer that wasnt an opinion.
When you build your robot, do you go and say "I think this part should be xxx in length" while another team member says "No, it should be xxx long" and yet another says the same thing, until you have 20 people all saying what they think is the right dimension? No! you get a tape measure, and you measure it. Or in this case, ask FIRST.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2004, 23:44
TomWx's Avatar
TomWx TomWx is offline
AKA: Tom Wexler
FRC #0708 (Hatters Robotics)
TomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to behold
Send a message via AIM to TomWx
Originally Posted by psycho7
As long as the robot is only using the vertical bar to keep its self from swinging and is not attached then it should be okay. But you never know when you may get a really annoying ref. (you know what I mean here)
A recent Q&A post expanded on the "swinging": A robot can "swing" for approximately, but no more than, ten seconds once a match has stopped. The requirements for the points stay the same, that a robot can be touching and ONLY touching the horizontal bar at the end of a match. IT may not touch another robot, pole, ball, carpet, goal, or any other part of the playing field.
Tom Wexler
FIRST Volunteer Coordinator, SCH District and Championship - Newton Field
Mentor, Team 708 Hatters Robotics
Unread 16-01-2004, 23:49
Meredith Rice's Avatar
Meredith Rice Meredith Rice is offline
None #0433 (Firebirds)
Meredith Rice has a spectacular aura aboutMeredith Rice has a spectacular aura aboutMeredith Rice has a spectacular aura about
Send a message via AIM to Meredith Rice
With the exception if a robot is pinned to the vertical poles by another haging robot but the robot is still supported by horizontal bar
I'm proud to be a....
~*Looks like I've got FIRST fever again*~
Unread 17-01-2004, 00:31
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
If you draw support vectors, you will see that if the robot is being supported by both the side and the top bar. Resulting, it would not be supported exclusivley by the bar.
Sorry, you can't do it!!
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 17-01-2004, 00:51
psycho7 psycho7 is offline
pyscho
AKA: (ex-freshman)
FRC #1831 (Screaming Eagles)
Team Role: Scout
psycho7 is on a distinguished road
Send a message via AIM to psycho7
if there are more than two robots hanging from the pole more then likely they will touch. as long as the hanging robots are touching nothing, besides the bar and it's supports, that is on the ground then it's okay.
Definitions of Nerd and Geek: Geek-the people who go to dances, try and dance,and get beaten up. Nerd- those who stay home during the dances and study.
by week two of FIRST robotics, everything needed to be done as of last week.
think outside the box.
what is 1+1=?
answers:
window;11;2;mace
Unread 17-01-2004, 01:20
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
This thread needs to be clarified and closed. People need to read the rules. If it is found that I have incorrectly stated the rules in this post, I will request that it be deleted as to not add confusion.
Defintions
Originally Posted by G4.3.1
HANGING – A ROBOT is considered HANGING from the Pull-Up Bar if it is directly SUPPORTED by the horizontal bar and is not touching the carpet, platforms, or goals.
SUPPORTED – If the "supporting object" is removed, the ball would not remain SCORED or CAPPED and/or the ROBOT would not remain HANGING.
Rephrased for leaning against the vertical bars on the side
Originally Posted by G4.3.1 Rephrased for Hanging
SUPPORTED – If the vertical bar is removed, would the ROBOT remain HANGING? If so, then it is not SUPPORTED by the vertical bar.
Incorrect Posts
Originally Posted by tenfour
If you draw support vectors, you will see that if the robot is being supported by both the side and the top bar. Resulting, it would not be supported exclusivley by the bar. Sorry, you can't do it!!
THIS IS FALSE. READ HANGING and SUPPORTED.
THIS IS FALSE. THE ONLY OFFICAL RESPONSE WITH "10 SECONDS" WAS:
Originally Posted by Q&A
Q:Would a hanging robot be scored if, after being powered down, it periodicaly touches the ground, but would eventually settle in a position where it would not touch the ground?
A:"Eventually" is typically about 10 seconds. If objects have not come to rest by then, the referees may disallow its score.
The last part stating a robot can only touch the horizontal bar and nothing else is not true.
The Question Everyone is Asking
..........|x____
..robot.|
The way it is written, if you remove the vertical bar, your robot would swing down and be suppported by the horizontal bar. To the best of my knowledge, nothing in the rules and the definitions of SUPPORTED and HANGING exclude this robot from scoring points. However, if the robot would swing down and hit the platform (12 inches above the ground) it would NOT receive the bonus.
If someone would like to show me a response where it said you can not touch any other robots or the vertical bar, that'd be great. Every answer refers to to the definitions... please read them before you ask, and more importantly, before you answer.
Good luck everyone!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 17-01-2004, 17:51
AKA: Gumby
Here's the Q and A that has me worried:
Section: 7.6 Status: Answered Date Answered: 1/16/2004
Q: If a robot is SUPPORTED only by the horizontal bar, but is
stabilized by being in contact with a vertical bar, is it attached to
the bar? No mechanism grips the vertical bar, and the robot would
still hang if the vertical bar was "removed."
A: Yes.
_________________________________________________
From the manual:
<T04> Robots may not intentionally:
• Attach themselves to the vertical supports of the pull-up bar
system;
__________________________________________________
My interpretation of this answer is that if the hook is in the corner it is being stabilized by the vertical bar and therefore considered attached which is not allowed.
Unread 17-01-2004, 19:52
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
I just asked a question to clarify the Q&A you're worried about. I think they answered yet to attached to the horizontal bar instead of the vertical bar. The question didn't specify which bar it would be considered attached to.
I think this is an answer that should put this topic to ease:
Originally Posted by FIRST Q&A
Q:Would a robot receive the 50 points if, by design, it would be leaning on (but not supported by) the vertical bar?
A:Please read the many other answers on this topic but... yes as long as you are not in violation of HANGING or SUPPORTED.
Matt
Falling off the bar... :\ Swampmonkey General Forum 47 14-03-2004 12:47
Raising the bar...or lowering it? Ben Mitchell General Forum 29 13-01-2004 03:30
Make the bar lower to get on? tkwetzel Rules/Strategy 28 12-01-2004 05:57
Vertical bar interaction Madison Rules/Strategy 5 10-01-2004 16:22
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
