Go to Post you must understand when wearing that FIRST Volunteer shirt, you personally & directly represent FIRST, and you do the best job for FIRST as an organization, that you can in performing that job....Period. - cglrcng [more]
Unread 17-01-2004, 02:25
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Example Beacon Tracking Code Posted
I've just posted a stand-alone example that demonstrates the infrared beacon tracker(s) without the navigation code. Start with this code if you want to write your own navigation code or just want to see the tracker(s) in action. A hint of how to calculate distance and heading to the beacon can be found in user_routines_fast.c/Process_Data_From_Local_IO( ). Tracker.zip can be found here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
Last edited by Kevin Watson : 17-01-2004 at 02:31. Reason: Egregious spelling error.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Official Beacon Tracking Code Posted Kevin Watson Programming 41 18-02-2004 21:04
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
