Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Unread 17-01-2004, 08:24
REVving up for a new season
FRC #2848 (All-sparks)
Re: Removing Bosch Drill Pins - Cause of Failure?
Originally Posted by ryan_f
with our experience last year, after we took out the pins, our clutch started slipping and wouldnt stop. We tried changing the clutch setting but that wasn't the problem. So we actually had to weld the clutch together to stop the slipping. The drill transmission kept falling apart after every match and we kept putting it back together. But after a while parts wore out on it and it just wouldn't work. So we got two new drill transmissions and left them alone. We never had any problems after that.
the clutch plate is in a completely different location from the pins (you don't need to go to that bottom layer of planets where the cluch is so i can't see any reason that THIS would have caused the problem. although it is possible that incorrect reassembling could have lead to the problem...for this reason i also recomend taking the gear boxes apart slowly and over a white piece of paper.
Bosch Drill Motor rmmlg Inventor 7 17-12-2003 14:33
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Bosch Drill Motor CAD Files Madison Inventor 10 09-12-2001 00:14
