Go to Post TIME is the one commodity you cannot buy more of. - Andy Brockway [more]
Unread 17-01-2004, 10:15
Brawler006 Brawler006 is offline
#1206 (Wrench Warriors)
Brawler006 is an unknown quantity at this point
Question Gears for CIMs
Does anyone know the best place to find gears for the CIM motors? My team is trying to build a gearbox with 2 cims, and we can't find anyplace that carries metric gears.
Unread 17-01-2004, 10:45
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Re: Gears for CIMs
Most large gear comapnies will carry metric gears with an 8mm bore to fit the output shaft of the CIM. However don't be limited to just metric gears, as a standard gear with a bore a bit smaller will also do the job. I used a 12tooth gear from Small Parts (a Martin Gear) that had a bore of .313 which is just under the ~.315 inch conversion of 8mm.
For any gears, metric included, try www.sdp-si.com, www.pic-design.com, www.wmberg.com, www.bostongear.com, www.nordex.com, as good old www.smallparts.com.
-Rc
Unread 17-01-2004, 12:04
Re: Gears for CIMs
thanks, that helps alot
Unread 17-01-2004, 20:01
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Gears for CIMs
Fortunately, this isn't a problem since the shaft size on the chip has a 0.313 diameter bore, which is the fractional 5/16". This isn't a super-standard size (1/8 inch increments are easier to find) but they you'll be able to compare a number of solutions at http://www.globalspec.com.
I hope this helps,
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 18-01-2004, 09:33
FRC #0030 (FURY)
Team Role: Driver
Re: Gears for CIMs
Matt,
The bore on the CIMs this year is an 8mm keyed shaft as per page 1, section 6 "The Kit". While the spec sheet from last year lists it as .313 +/- .0004. Either gear will do fine, a .313 is just a tighter fit, and needs a little "coercing" to go on the shaft. An 8mm bore should spin freely on the shaft without any need for some help to be put on. I did this exact same thing on Thursday, so I am more confident in the kits listed 8mm.
-Rc
Unread 18-01-2004, 09:46
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Re: Gears for CIMs
Originally Posted by Ryan Curry
The bore on the CIMs this year is an 8mm keyed shaft as per page 1, section 6 "The Kit". While the spec sheet from last year lists it as .313 +/- .0004. Either gear will do fine.
Agreed.
I was just saying that if you can't find metric gears or you don't wish to use metric gears, you don't have to. On 461, we're trying trying to the standardize to English units.
Matt
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
