Go to Post This game is absolutely *NOT* too difficult, but many teams will make it too difficult by biting off more than they can chew. - pfreivald [more]
Unread 17-01-2004, 12:31
IronSlayTallica IronSlayTallica is offline
IronSlayTallica is an unknown quantity at this point
Unhappy Everybody Standby!!!
We seem to have a problem. Our robot is on. The tethers are connected. The radios are connected. The RC and the OI are connected to everything they need to be connected to. And yet, "*BLINK BLINK* No Data/Radio." AND! The program IS loaded into the RC. The RC is happy. It has green lights. It's ready to go. But the OI blinks uncontrollably. It just doesn't seem happy. We've been working on this for two days now. Our main programmer can't seem to find the problem and he's an UberNerd. Help?
Unread 17-01-2004, 13:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Everybody Standby!!!
This may sound really stupid, but have you checked all the obvious stuff, like setting your team # (Does this have any effect outside of the competition?) making sure that you have the AC adapter for the OI, double checking that everything is in the right place, etc?
2001-2004: Team 100
2006-Present: Team 254
Unread 17-01-2004, 13:05
No, you don't sound stupid. I won't go and tell you how incredibly stupid my friend and I are for now... but yes, team number was up, ac adapter plugged in, etc. It's an unhappy OI.
Unread 17-01-2004, 13:48
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
This is my first year actually working on our robot, so I have almost no experience with this. Still, two suggestions:
1.) Check the manual. Make sure that everything is connected correctly.
2.) Try running the robot without the tether. It's possible that the cable itself is bad.
3.) If you can get your hands on another OI (maybe borrow one from another team), try that out instead of yours. The OI could be the problem, but I'm not sure how likely that would be.
4.) If you're really stumped, contact another team in your area. With any luck they'll be able to help you out.
Unread 17-01-2004, 18:08
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
At risk of sounding incredibly stupid... Have you checked your "backup battery" that plugs into the controller and your connections to sensors and motor controllers??
It's all fun and games till the bosh motor breaks.....
Unread 17-01-2004, 21:33
Bruce C.'s Avatar
Bruce C. Bruce C. is offline
#0647 (The Cyber Wolf Corps)
Bruce C. will become famous soon enough
Checking the obvious, again, but it sounds like you have BOTH the tether and the radios connected? Did you follow the procedure in the start up guide to use the tether first, without the radios, to download the team number into the RC, and get it working, THEN disconnect the tether and try the radios?
Unread 17-01-2004, 22:14
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
have you tried using the default code? we had that problem using last years controller. But im not the programmer, i might sound like an idiot to the rest of the free world. So, with that out of the way, is this your code or the default, try running the default code to test if it is your code or the hardware...
hope that made sence, it did to me, but hey, im weird
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 18-01-2004, 03:50
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
Just to clarify some stuff. You do NOT need the 7.2 battery to set the team number etc... I used the default breakers and hooked it up to the 12 V battery.
Steps...
1. Turn on OI
2. Set team number
3. Turn on RC
4. Hold program down
5. Program (doesn't seem to reset on first program)
6. Reset
7. Hook up tether from RC to OI, it should auto-calibrate team.
8. You're done.
Thanks,
Ryan Waliany
R
Unread 18-01-2004, 09:57
Well, thank you for all your help. I'm not the head programmer of the team, but as I said, he was having trouble with it too. I'll be sure to try your suggestions on Monday. Sadly enough, my team doesn't have Sunday meetings which is terrible considering that we've already had snow days that interfered with building days.
Thanks Again!
Unread 18-01-2004, 10:02
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I'm not sure, but I think our programmers tried that the other night. I remember we had this problem last year at the UTC regional, and it wound up that we had a bad OI unit. I believe the person that was in charge of the event came over and talked to use for about an hour or so and gave us a new unit, which solved the problem. It was the same situation as we are having this year. The OI worked while we were testing then just went dead. The interface was working on Thursday I believe, then stopped working Friday night. We also had problems with our radio cable the same year, cutting in and out, which I don't think is the problem this year. I might take a look at it tommorow morning and see if i can diagnos the problem, if there is one. I'm also wondering if the interface will work with the relays and speed controllers from 2 years ago, I'm positive they will, but you never know.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 18-01-2004, 11:57
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
You're not trying to use an old OI by chance, are you? OIs from previous years won't link up with the new RC.
Most of this has already been mentioned, but:
- Swap out all the cables one by one to make sure it's not a bad cable
- Any difference between running it with a tether versus wirelessly?
- Is the OI unplugged from the power adapter when you're tethering it?
- Is the robot's battery sufficiently charged?
- Relays and speed controllers from last year should work, but I'd try unpluggging all joysticks from the OI and all inputs/outputs from the RC to try to eliminate a problem there
- When using the radio modems, are the LEDs lit up? The transmit LED on the OI should be flickering
- Along those lines, try a different radio channel to make sure it's not an interference issue (directions should be in the IFI manuals)
Let us know if you make any progress...
Unread 18-01-2004, 12:13
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
no, both the OI and RC are from this year
Unread 20-01-2004, 11:21
Well, our programmer placed a call down to Texas and we found the problem and the answer. There was a series of buttons and commands and such to do and now it's fixed. wo0t! Thanks for all your help
Unread 23-01-2004, 00:07
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Can you share this series of buttons & commands with us? One second our RC was working fine, the next it was dead. No connection between the OI & RC over radio or tethered, solid yellow 'program' light even though the default code was just downloaded to it. The user processor is running because we get debug data over the serial cable, but we can't get anything else to work. What's the secret to get it working?
Unread 23-01-2004, 02:40
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Sounds like a bug in the master code (LEDs and radio are both master functions correct?). I guess their series of buttons and commands resets the master?
Though I would think unplugging all power would solve a bug in the master code. Unless its due to something stored in EEPROM or program mem.
...does anyone else REALLY want to see the master code? I don't see how it could be a security risk.
