Go to Post Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of... - jvriezen [more]
Unread 17-01-2004, 13:42
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Official Beacon Tracking Code Posted
Originally Posted by Krash
Kevin,
Is there a "Theory of Operation" or White paper available to explain how this all works?
Not yet. I need to find the time to complete it.
I am assuming that type-0 operates on one side of the field and type-1 operates on the other side. Is this correct?
Yes, this is correct.
Also, is the waveform chart on your website accurate? I assume that the pulse repetition interval's (PRI) are fixed as depicted on the chart.
Yes, the waveforms are accurate. The beacon flash rate is fixed at 100Hz.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2004, 13:51
FRC #2429
Originally Posted by Phil Roth
Kevin,
Thanks for the link explaining that the system uses BOTH beacons instead of ONE. I guess it finally clicked. I had trouble understanding how to manuever both directions ( left and right )using using a single "line of sight" source. My trig skills havn't been used in 20 years so I hope the students can help us out with triangulation.
I am still a little confused why 4 receiving LEDS are used and not 2, 1 for each beacon. ??
-Phil
No, actually the tracking software uses just one beacon for tracking. The type that it tracks is selected using a switch on digital I/O 7. We use four receiving sensors for speed and it simplified the tracking algorithm significantly (I'm still writing the theory of operation).
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2004, 14:12
Atheist Atheist is offline
Atheist is on a distinguished road
What if both sensors are in view?
Unread 17-01-2004, 14:26
FRC #2429
Assuming the tracking assembly is correctly constructed, it means the tracker is pointed at the beacon. If you really meant to ask what if both beacons are in view?, the system is designed to easilly handle this because the type-0 and type-1 beacons are never flashing at the same time (assuming both beacons are being driven by one EDU-RC).
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2004, 14:30
Heh, pretty early in the morning for me, ye I meant beacons not sensors. So if both beacons are in view, then the trackers would keep switching back and forth from one beacon to the other depending on which one is flashing???
Unread 17-01-2004, 14:37
FRC #2429
No, the trackers will only track the beacon you want it to track (as selected by a switch on digital I/O 7).
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2004, 14:48
I see, thanks. Let see if I understand how the navigation code works:
The servos are constantly rotating attempting to follow the beacon. While this is happening the bot navigates to the beacon by moving in the direction that causes the angles with respect to the beacon and the trackers to become smaller? When the angle becomes small enough it assumes that it is in front of the beacon?
Unread 23-01-2004, 20:17
rosebud rosebud is offline
#0115 (MVRT)
rosebud is on a distinguished road
hi kevin,
my team is having trouble downloading the navigation code onto our frc. our project builds fine, we can download other programs like beacon onto our edubot, so i dont think it is ifi loader or mplab, but when we download tracker or navigation the frc either crashes, doesnt get out of program state, or sends back a file called error.mcp that i think has address and hex op codes or something. do u know what is wrong? thanks
becca
electrical officer
115 monta vista high school
Unread 23-01-2004, 20:58
FRC #2429
Originally Posted by rosebud
hi kevin,
becca
electrical officer
Can you successfully load the default code for the FRC-RC? I've also noticed that sometimes when you download code to the EDU-RC and FRC-RC, the transfer was successful but the program light stays on until you power cycle or reset the controller at which time the controller functions as expected. Have you tried that?
-Kevin
Kevin Watson
http://kevin.org
Unread 23-01-2004, 23:29
doy's Avatar
doy doy is offline
#1208 Ex-Lead Programmer
AKA: Jesse Luehrs
#1208 (The Super Critical Axe Men)
doy is on a distinguished road
Send a message via AIM to doy
Originally Posted by Rickertsen2
Thanks. That scheme is relatively simple. Maybie if i find some time(not likley) i will post an alernative circuit, for those who do not wnat to use the edubot. This setup is easy to replicate using a handful of resistors, capacitors, and 555 timers.
Hmmm... I might have to look into the whole triangulation thing.
hey, did you ever get that circuit working?
Unread 23-01-2004, 23:46
danielkitchener's Avatar
danielkitchener danielkitchener is offline
408 Computer Nerd
AKA: Daniel Kitchener
#0408 (Roboticks)
danielkitchener is on a distinguished road
AArgh...
Can anyone help out a confused person?
First, should we use 180-degree servos or 360-degree ones?
Second, minimum and maximum values for the servos are 0 and 254, respectively, right?
Third, is left servo position-127=right servo position, the beacon is centered, right?
Unread 24-01-2004, 16:17
#0115 (MVRT)
yes, we have successfully downloaded the frc default program. we have also tried to reset the controller, and when we do, the controller goes back into program state instead of running the program. has anyone else had this problem? i didnt change the navigation code before i downloaded it to the frc. thanks
becca
Unread 25-01-2004, 18:28
Guest
Posts: n/a
Originally Posted by Kevin Watson
I've posted the official IR beacon and IR beacon tracking and navigation code that was used at the kick-off here: http://kevin.org/frc. The folks at IFI will also be posting the code on their website. If you have questions about the code, please leave 'em here and I'll try to keep up .
-Kevin
Can you add this to the repository?
http://nrg.chaosnet.org/repository - You'll need to register
Unread 25-01-2004, 20:03
tml240's Avatar
tml240 tml240 is offline
bahh
tml240 is on a distinguished road
we uploaded beacon code on the edurobot and the navigate code on the FRC robot to test if the IR things work. we got the ir beacons and the receivers on the right spot....are those the codes that suppose to work together?
or how do we test the beacon?
OHL 2004- ultimate NHL 2004 MOD
Unread 25-01-2004, 20:26
FRC #2429
If all you want to do is test the beacon and trackers, load beacon.hex into the EDU-RC and tracker.hex (included in tracker.zip) into the FRC-RC. The code in navigate.zip assumes that it's running on a real 'bot.
-Kevin
Kevin Watson
http://kevin.org
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
