Go to Post Sloppy thinking leads to sloppy designs... - Joe Johnson [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 17-01-2004, 01:06
iBob's Avatar
iBob iBob is offline
Extreme Mac Geek
AKA: Christopher Jones
#0240 (Mach Vee)
Team Role: Webmaster
iBob is an unknown quantity at this point
Send a message via AIM to iBob Send a message via Yahoo to iBob
Code problem
Seems i'm missing something... I've got this page I'm trying to work with, I'm playing with php and html. http://scnc.jefferson.k12.mi.us/phpi...ate=2004 0117 I can't seem to find where I'm going wrong. I want the design, the yellow to continue across, as far as i can tell it should. I set that table to be 100%... but its not working... anyone see where I'm going wrong?
Visit Team 240's Homepage
Unread 17-01-2004, 01:15
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Re: Code problem
If you go on your html page, and scroll down to where your links are... on that bar.... you will see this:
<td colspan="2" bgcolor="#FFCC00">
simply change it to this:
<td colspan="3" bgcolor="#FFCC00">
That will fix your problem. Good luck.
Chopsaw? Chopsaw.
Unread 17-01-2004, 01:17
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Code problem
only thing i could think of is that somehow you have 3 cells in the row that contains the main content, because the "Site Map" link is also not on the far side, and where the yellow stops is exactly where the calendar column begins, which points strongly towards a third column there (which the colspan="2" isn't handling)
you could try just changing the colspan="2" to colspan="3"
--edit--
heh, we both managed to post at the same time
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 17-01-2004, 14:14
iBob's Avatar
Extreme Mac Geek
#0240 (Mach Vee)
Re: Code problem
Thanks miketwalker, that did the trick.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
One final fairly massive problem with the code... authgeek1218 Programming 5 19-02-2003 16:51
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
