Go to Post This year it is what it is and, at some point, we will all find out what that is, specifically. - JaneYoung [more]
Unread 17-01-2004, 15:01
Stormhammer's Avatar
Stormhammer Stormhammer is offline
Team 1183
AKA: Justin
#1183 (Eagle Executioner's)
Team Role: Driver
Stormhammer can only hope to improve
Send a message via AIM to Stormhammer Send a message via Yahoo to Stormhammer
Exclamation Setting motor in cradle
help! I've tried setting up the Bosch drill setups in the plastic cradle's but I cant seem to figure it out, its already resulted in one drill coming apart and me having to put it back together. Any input would be helpful.
Unread 17-01-2004, 20:12
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Re: Setting motor in cradle
The drill motors should fit very snuggly in there. If you look at that large bottom part of the plastics cradle there should be one side that is notched out a little. Just look at the drill motor and the clutch and see what will go in there, i think its the clutch but i could be mistaken. Then just line up the tops with the bottom and it should be all set. Just make sure you put bolts and nuts in the holes so it doesnt come apart.
Also if you drill motor and clutch came apart while putting it into the cradle, then you did not insert the drill motor correctly. Look at the drill motor, there are two holes on the shaft side, that line up with two extrustions on the clutch assembly. It sould just click in and should not come out easily.
Unread 20-01-2004, 15:41
Team 1183
AKA: Justin
Team Role: Driver
alright I'll try that, Thanks!
1-2-3 EXE... prepare to be executed - Eagle Executioners ( no more Eagle Engineers ) #1183
Its either a Mopar or no car
Dude, WHY ARE YOU SO SLOW?!?!
Unread 20-01-2004, 15:49
Team 1183
AKA: Justin
Team Role: Driver
also just to ask, can anyone possibly provide a photo I wanna be able to do this without breaking anything
Unread 20-01-2004, 15:51
Team 1183
AKA: Justin
Team Role: Driver
Got It Woohoo!! Thank You Very Much~!
Setting up a webcam D.J. Fluck Chit-Chat 1 08-09-2003 01:32
Need help setting up phpBB on a coolfreepages.com website LBK Rules Website Design/Showcase 5 30-03-2003 20:02
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
Jealousy is setting in now!!!! archiver 2000 5 23-06-2002 23:46
