Go to Post So perhaps those that are so eager to complain might realize that if they spent a little less time complaining and a little more time analyzing the problem and developing solutions, then they might have a little less to complain about. - dlavery [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 17-01-2004, 18:50
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Calculating Wheel Size To Climb
It seems like one prevalent method that will be used this year to get onto the platforms will be to utilize big wheels. I tried to calculate how big such a wheel would be needed using a 130lb robot but didn't come up with a way to do it. Can someone with a deeper physics background explain the method?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 17-01-2004, 19:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Calculating Wheel Size To Climb
Generally, I believe that you need 2/3 of the wheel to be beneath the step. Anyone with a physics background care to confirm/deny this?
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 17-01-2004, 19:23
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Calculating Wheel Size To Climb
The short story is that any 4-wheel driven drive train could climb up the 6" lip assuming the coefficient of friction is high enough and the motor torque was high enough. However, the true problem is in "bottoming out" ie where the bottom of your robot or some component will actually scrape along the edge of the step before your back wheel climbs the back step.
To ensure this doesn't happen you can just choose a wheel size that has a radius larger than what you wish to climb, and mount it such that the bottom of your frame is taller than the 6" step- you're able to let both wheels stay in constant contact with the ground.
However, one should note that there exists a very real fear of tipping. A robot with a high center of gravity could potentially tip while attempting a feat such as this. If you would like some calculations for when tipping occurs, please let me know.
I hope this (briefly) points you in the right direction.
As to Cory's comment about 2/3's... I've never heard of such a thing, though I know that a wheel with a radius higher than the step size will have a mechanical advantage, since you simply need to rotate about the point, as opposed to climb the wall.
Good luck!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 17-01-2004, 19:36
Cory's Avatar
AKA: Cory McBride
Matt, you are right, we tested our robot out last night, using a piston to lift up the front of the robot. The one we used only got us to about the midpoint of our wheels, but since we had so much torque, we were able to drive right up. If you do it all in one continuous motion, and you have enough torque, you actually wont high center the frame. If you stop midway, however, youre stuck.
I believe the reason I heard the 2/3's thing was so that you could know exactly how large of a wheel would get you over, no questions asked. I very likely am wrong though.
Cory
2001-2004: Team 100
Unread 17-01-2004, 20:00
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
I would like to see the tipping calculations.
Unread 17-01-2004, 20:10
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Our robot from last year was able to climb a six inch step with a slight modification. We added two non-driven wheels on the front to lift the front up to the first set of wheels. This was with a four wheel drive system with 8.5" wheels that have lots of traction (go-kart racing slicks). We are planning on going to a 10" pneumatic tire though. We want to smoothly make our way onto the platform, not ram our way up.
Unread 18-01-2004, 02:37
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
There are more variables to consider than just wheel size. MIT's 2.007 course has some very good info on this subject online. There's even a handy Excell spreadsheet for calculating the ability of wheeled vehicles to climb obstacles. Link follows:
Wheel Climb.xls
-Joel
Unread 18-01-2004, 05:04
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
As Joel said, wheel size is not the ultimate determining factor for climbing stairs. One good example of this is the Personal Rover Project's Rover1, which can climb a 7 inch step with 2 inch wheels.
Zan Hecht
Unread 18-01-2004, 18:23
Eric Thompson's Avatar
Eric Thompson Eric Thompson is offline
Go patriots!
#1415 (Astroguard)
Eric Thompson is an unknown quantity at this point
My team is wanting to get up the platform on the side in order to bypass the "small" space where the goals are. Is it possible to have a two wheel drive in the front with casters in the back and still be able to get up the incline? One of our team's teachers said that it was possible but im having doubts about it bottoming out. The person that designed the drive system or body says that the robot can and/or will be 6in or below from the floor. Im just the Arm Captain, but am I freaking out or what?
Eric Thompson
Northside High
Team 1415
Columbus Georgia
Unread 18-01-2004, 18:36
Anne Shade Anne Shade is offline
Maryland Regional Director
AKA: Formely Anne Bergeron
no team (FIRST Chesapeake)
Anne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond repute
Send a message via AIM to Anne Shade
I would really advise against having castors in the back if you want to climb. The big problem with castors is that you can't control their orientation so it will make it very difficult to control the direction of your robot with your back end spinning away. Having skids or non-powered wheels would be better than castors. Even better would be a 4 wheel drive. If you have any questions about how to do this, email me. The GT FIRST group in GA is here to help all the GA teams as much as we can. You can also IM me if you need to at Astroanne10.
Anne Shade
Past Teams: 132, 408, 608, 832, 1002, and 2377
Unread 18-01-2004, 20:44
You dont need big wheels to climb a step
ever see a kid go UP a curb on a skateboard?
with a little momentum your wheel doesnt have to hit the face of the step at all - if you get creative :^)
BTW - did I ever mention that when I was a kid, "Speed Racer" was my favorite saturday morning cartoon?
Unread 18-01-2004, 21:52
AKA: Nelson Green
We know their is much more than wheel size but is does help in several ways. Higher clearance and more lift by an indivual wheel. We are testing 8 wheeled designs. 3 driven and 1 not. From are test we might be able to use eight but it is much smoother with 10 for us. and a inch in height will not through our center of gravity off much. Using four wheel drive you could climb the step with two wheels. The robot would have to have a lot of clearance and large wheels, say bigger than 12". Two wheel drive with casters would be hard, it might be possible but I wouldn't reccomend it.
Unread 18-01-2004, 22:49
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
I beleive the numbers one of the engineers on our team from a tire company decided you would need somewhere in the ballpark of 18 inches to "comfortably" climb the 6-inch step. We quickly decided on a better method....
It's all fun and games till the bosh motor breaks.....
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
A file size issue Funkymunkey90 3D Animation and Competition 2 05-02-2002 14:50
