Go to Post ...because "someone on ChiefDelphi said so," doesn't fly when your robot can't pass inspection. - Madison [more]
Unread 17-01-2004, 18:39
Stormhammer's Avatar
Stormhammer Stormhammer is offline
Team 1183
AKA: Justin
#1183 (Eagle Executioner's)
Team Role: Driver
Stormhammer can only hope to improve
Send a message via AIM to Stormhammer Send a message via Yahoo to Stormhammer
Exclamation How to Hang
hey, I'm not asking you guys for what you are doing to hang ( but by all means tell if you want ) but our team needs some pointers on how to have something get up to 10ft. One of our ideas was a pneumatic arm... but you can prolly see the problem with this. Help anyone? and remember, its nice to help, cause we might be your ally in some match
1-2-3 EXE... prepare to be executed - Eagle Executioners ( no more Eagle Engineers ) #1183
Its either a Mopar or no car
Dude, WHY ARE YOU SO SLOW?!?!
Unread 17-01-2004, 18:59
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: How to Hang
One of the biggest sources of ideas for you could come from the Chief Delphi image gallery. Scan through the 2000 gallery... There was both hanging and ball collection (same size balls as this year) that year.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 17-01-2004, 19:01
Jeremy Roberts's Avatar
Jeremy Roberts Jeremy Roberts is offline
Coach 4026
FRC #4026 (Global Dynamics)
Jeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant futureJeremy Roberts has a brilliant future
Send a message via AIM to Jeremy Roberts
Re: How to Hang
Search around and you will find threads on this topic already. One being here. Also take a look at some of the robot pics available from the 2000 game. If you have more questions feel free to contact me. We are here to help you in GA.
Jeremy Roberts
GeorgiaFIRST Planning Committee | Peachtree Regional
Georgia Tech RoboJackets FIRST Co-Founder
Engineer/Mentor 4026
Former teams: 132, 608, 832, 1002, 1848
Unread 17-01-2004, 19:11
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Re: How to Hang
Originally Posted by Stormhammer
... One of our ideas was a pneumatic arm... but you can prolly see the problem with this. Help anyone? ...
What is the problem with this?
You can order 3 free cylinders of up to 24" stroke each ....
Unread 17-01-2004, 20:14
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Re: How to Hang
The problem is that compressed air can be compressed further. Incorrect design/planning could lead to your robot sliding back down your cylinders and ending up back on the floor.
There are ways to prevent this, but there is another thread about that. Search it.
Unread 17-01-2004, 21:07
Team 1183
AKA: Justin
Team Role: Driver
Re: How to Hang
alright thanks! I'll check it out! also, is there any danger in say, your hanging off the bar right? well, what if the enemy team decides to hit your robot? say they're just trying to get by? is that an illegal move or what? cause if it isnt, then I dont feel like seeing a pneumatic arm breaking off...
Unread 17-01-2004, 21:16
disturbedislife's Avatar
disturbedislife disturbedislife is offline
frederique
AKA: molly
#1288 (team raven)
Team Role: Scout
disturbedislife is on a distinguished road
Send a message via AIM to disturbedislife Send a message via Yahoo to disturbedislife
Question Re: How to Hang
that is a good question....
~Molly~
2004 St. Louis regional quarter finalists
2004 St. Louis Regional Highest Seeding Rookie Team
2005 St. Louis regional semi-finalists
-I own your soul indefinately.-
Unread 17-01-2004, 21:22
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: How to Hang
Yes and no. Compressed air can be compressed more but it won't be very much compression if you are using it at near 60 psi. That is not the problem. If you make sure to lift yourself more than a couple inches from the ground and don't have any leaks in the system you should have no problem with staying up. One problem tends to be that with a 130 lb robot it will take a 2" bore 48si of pressure to cause the lift need to pull it up. That is not including the dip in pressure the lift would cause making it more like 55-60 psi to complete the lift. Compression would happen but with a 2" bore with 50-60 psi it wouldn't be more than a couple inches.
My personal tip to everyone is to not use pneumatic to lift the robot up but use "the force" like my team hopes to. We have bypassed robot designed to train in the art of the Jedi and we plan to have mastered "the force" by the time we get to Houston and Atlanta. My team pledges to use "the force" with gracious professionalism when using it. May "the force" be with us.
Plan B involves calling on "the swartz" while dangling a lucky rabbits foot.
Unread 17-01-2004, 23:08
Team 1183
AKA: Justin
Team Role: Driver
Re: How to Hang
Atlanta eh? I'll make sure to keep my eye's peeled for you guys too... I'll nab some of your lucky rabbits foots! I'll talk with my design guys with the info I've gotten.
Unread 18-01-2004, 00:16
batbotcrewfrosh batbotcrewfrosh is offline
#0677 (The WireStrippers)
batbotcrewfrosh is an unknown quantity at this point
Send a message via AIM to batbotcrewfrosh
Lightbulb Re: How to Hang
an idea: stick something sturdy up that hooks onto the bar, then lift the wheels ^^
The rock and pool, so nice and cool
So juicy SWEET!
Our only wish, to catch a fish
So juicy SWEET!
Build F.I.R.S.T, Sleep Later
Team #677
Sophomore (the Frosh thing is a bit of a lasting fad... O_o; )
Size Is Large archiver 2000 15 23-06-2002 22:47
Team 56 Robbe Xtreme will hang in FL archiver 2000 0 23-06-2002 22:39
control system programming archiver 2000 17 23-06-2002 22:14
How many robot can hang on at the same time? archiver 2000 3 23-06-2002 22:03
How many are going to competition without a team? Ken Leung General Forum 6 17-03-2002 14:01
