Go to Post For what it's worth, while they may or may not be legal as safety glasses, Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Unread 17-01-2004, 07:29
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
Question Using the extern keyword.
I'm trying to make a variable in the user_routines_fast.c file that can be accessed in the user_routines.c file. How do I do this. I think it uses the extern keyword? Am I wrong? If I'm not. How do I properly use it. Thanks.
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
Unread 17-01-2004, 08:06
m0rph3us's Avatar
m0rph3us m0rph3us is offline
AKA: Andre
#0293 (Spike)
m0rph3us will become famous soon enough
Send a message via ICQ to m0rph3us Send a message via AIM to m0rph3us Send a message via MSN to m0rph3us Send a message via Yahoo to m0rph3us
Re: Using the extern keyword.
Yes the you can use the keyword extern like the following:
//user_routines_fast.c
int foo;
//user_routines.c
extern int foo;
void test()
foo=2;
But the more professional way of doing this is by declaring the variable in user_routines.h where than you don't have to use extern but rather only have to include the file user_routines.h (as it is already done in the default code)
Andre
Team S.P.I.K.E.293
Unread 17-01-2004, 10:45
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
no, do not define the variable in user_routines.h - this does not actually share the variable. instead, you get two copies, one in each file. (remember, putting something in an include file is just like inserting that text into each file in which you #include it). if you look at the user_routines.h file, you will notice that there is not a single actual variable defined there - there's a reason for that.
extern is probably the way to go here, just declare the variable in one file, then copy the definition to the other but tack "extern " on the front. if you're passing more than one thing back and forth, you might consider creating a struct to keep all of the info in one single variable that can be extern-ed (having more than one or two global variables looks messy )
if you wanted to be ambitious, you could modify main.c so that Process_Data_From_Local_IO() and Process_Data_From_Master_uP() could return and be called with a value, thus passing the info that way (using a struct)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 18-01-2004, 00:31
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
Hmm, when the variable is changed in user_routines.c, do you have to extern it back in u_r_f.c? Like so:
/*user_routines_fast.c*/
int foo = 263;
extern user_routines_function();    /*Is this extern needed?*/
extern foo = foo - 1;               /*Do we need the extern now,
                                     *because it was modified in u_r.c?*/
/*user_routines.c*/
  extern foo = foo + 3;
Unread 18-01-2004, 02:07
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
int foo = 263;
/*user_routines.c*/
extern should never be used inside an expression like that. It is only used in declarations made at the file-scope level. Thus, you just do stuff like this:
int foo;
void myfunc(){
foo=foo+1;
/*user_routines.c*/
extern int foo;
void myfunc2(){
foo=foo+3;
They keyword extern is NEVER needed with function prototypes, as they are extern implicitly.
-Rob
Unread 18-01-2004, 02:08
Computer Guy
AKA: Dav
extern is only used in the first declaration of variable in a file - treat it just as if you were declaring the variable normally, extern just says "this variable was originally declared in another file, and the same copy should be used here".
also, remember that exactly one file should have the variable declared without "extern" - all of the other files extern this original declaration.
Finally, remember that extern only really works for global variables. So make sure your extern-ed variables are declared outside of any function calls.
--edit-- lol, it happened again.
Unread 20-01-2004, 12:48
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
I hate globals, and I hate the extern keyword.
If you can pass the variable as a parameter to any function where it's needed, do it that way. It's much cleaner, and less error-prone.
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 20-01-2004, 21:22
Computer Guy
AKA: Dav
only argument i'd have against that is in this case, that would mean modifying the main.c loop and code, which a beginner programmer might not want to do (however, I agree for the most part and would/will probably implement it in such a way myself).
