Does anyone know the best place to find gears for the CIM motors? My team is trying to build a gearbox with 2 cims, and we can't find anyplace that carries metric gears.
Re: Gears for CIMs
Most large gear comapnies will carry metric gears with an 8mm bore to fit the output shaft of the CIM. However don't be limited to just metric gears, as a standard gear with a bore a bit smaller will also do the job. I used a 12tooth gear from Small Parts (a Martin Gear) that had a bore of .313 which is just under the ~.315 inch conversion of 8mm.
For any gears, metric included, try www.sdp-si.com, www.pic-design.com, www.wmberg.com, www.bostongear.com, www.nordex.com, as good old www.smallparts.com. -Rc Last edited by Ryan Curry : 17-01-2004 at 14:35. |
Re: Gears for CIMs
thanks, that helps alot
Re: Gears for CIMs
I hope this helps, Matt |
Re: Gears for CIMs
Matt,
The bore on the CIMs this year is an 8mm keyed shaft as per page 1, section 6 "The Kit". While the spec sheet from last year lists it as .313 +/- .0004. Either gear will do fine, a .313 is just a tighter fit, and needs a little "coercing" to go on the shaft. An 8mm bore should spin freely on the shaft without any need for some help to be put on. I did this exact same thing on Thursday, so I am more confident in the kits listed 8mm. -Rc |
Re: Gears for CIMs
I was just saying that if you can't find metric gears or you don't wish to use metric gears, you don't have to. On 461, we're trying trying to the standardize to English units. ![]() Matt |
| What type of steel are gears commonly made from? | Matt Adams | Technical Discussion | 5 | 02-01-2004 23:19 |
| Helical gears that come with new drill motor | Joe P | Technical Discussion | 4 | 12-01-2003 11:09 |
| Best source for gears? Smallparts? drivetrain advice wanted! | Frank(Aflak) | Technical Discussion | 11 | 10-01-2003 17:22 |
| Need help! What kind of gears are we allowed to use?? | Randy_Ai | Technical Discussion | 3 | 23-01-2002 22:56 |
| replacement gears | joni_m | Technical Discussion | 1 | 22-01-2002 18:01 |
