Go to Post The FIRST World has your back. - MishraArtificer [more]
Unread 17-01-2004, 14:06
Brant Bowen Brant Bowen is offline
no team (AndyMark, Inc.)
Brant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant future
Send a message via AIM to Brant Bowen
Assistance With Tread
We are working on modeling prototypes for this years robot and we were wondering if any teams that have used tread before know how to draw it and make it function. I know that i can draw an outline of it pretty easily, extrude it, and cut out the part that is the inside, but that won't move around the track. Does anybody know how to make a tread that will move around a track?
Operations Manager - AndyMark Inc.
Co-Volunteer Coordinator - Boilermaker Regional, Crossroads Regional, Indiana Robotics Invitational
Unread 17-01-2004, 16:34
Tarzan Tarzan is offline
#0093 (New Apple Corps)
Tarzan is an unknown quantity at this point
Re: Assistance With Tread
you can use motion constraints to make a part move with respect to another. it's sort of complex if you haven't done it before so i suggest doing a couple of tutorials on the subject. there is one in the program or you can try www.sdotson.com both have decent tutorials that should help a bit
"You tried your best and you failed miserably. The lesson is 'never try'." - Homer Simpson
Unread 17-01-2004, 19:05
I actually just learned how to do motion constraints, but something seems to me that if i make a tread one solid piece it won't spin correctly. Wouldn't a tread have to be several different pieces inorder to perform a motion constraint on it correctly?
Unread 18-01-2004, 00:47
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
wow screws are really hard. u probably know this but u can use the cheap inventor "threads" to texture if the constaints wont work. or u could do a presentation and tweak the screws to move up and spin at the same time.
Unread 18-01-2004, 11:26
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
he means treads. As in tank treads.
And to answer your question, I don't think that Invento can even DO treads. All the objects you can add motion constraints to move or rotate, but do not deform. A tread must be constantly changing its shape to move around, unlike a wheel, gear, sprokect, rotating arm, pneumatic cylinder, etc. that only have to MOVE.
So I would say model it and put it on, and then move the wheels that drive the tread and tell your team to pretend that the tread is moving also.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 18-01-2004, 13:24
omg lol sry i read this at like 3 am. all i can say is that to make treads u will need circle and rectangle patterns. that is as much as i could do. try importing it into 3dsmax and messing with it
Unread 18-01-2004, 14:26
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I don't think inventor can do it.
It would be possible to do in solidworks, but would require rediculously complecated equations.
What you're asking inventor to do is change the profile of the tread with respect to the position of a wheel. Unless inventor supports equations or some other way of dynamically changing sketches I'm afraid your out of luck.
You might want to pause and ask yourself why you want to do this. Besides "it will look cool" I can't think of any. Remember that inventor is a CAD program and not ment to handle complex anamation tasks. I agree that it would look cool but your time is probably best spent elsewhere.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 20-01-2004, 23:01
it actually is possible to do treads if you do it in many different pieces (think a chain). dont know if you want to spend the time to do all of the constraints but it is possible to do. a LOT of work but would look really cool.
hope it helps
Image Discuss: 258's wheels with tread. CD47-Bot Extra Discussion 11 11-02-2003 18:32
Tread - Whats up with that? Colin Bohannan Technical Discussion 1 04-10-2002 21:08
Future Nuclear Field Engineer looking for Team that needs his assistance dickymon General Forum 3 29-04-2002 15:43
Tread or Wheels? Jordan A. Technical Discussion 28 10-01-2002 04:05
Non-Profit Status Assistance!!! John Larock General Forum 1 25-07-2001 16:36
