Go to Post Believe that Dave knows what he is talking about. - JaneYoung [more]
Unread 18-01-2004, 13:49
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
IR sensor question
Hi. Regarding the beacon, the manual states that the pulse is 50 hz. In the edu default code, the receive is set up for 100 hz. Which one is correct?
Thanks,
Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 18-01-2004, 14:35
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR sensor question
Thanks,
Daniel
It was originally to be 50Hz. We changed it to 100Hz so that we could have a faster control loop on the 'bot. Looks like the change didn't make it into the manual. I'll fire-off an e-mail to the FIRST engineering folks. Thanks for pointing this out.
-Kevin
Kevin Watson
http://kevin.org
