Go to Post "Fair and professional" needs to be two-directional. - John Neun [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-01-2004, 20:26
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
2x ball dosent roll straight
We have just been testing the big yellow ball, and we found that it dosent roll straight. It seems like there is a weight in the side or something. Was this just because we got a bad ball, or is this a common problem other teams are experiencing?
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 16-01-2004, 20:31
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: 2x ball dosent roll straight
This is common. Similar balls were used in 1995 and 1996 and they had the same characteristics. In fact, if you told me that you had a ball that did roll straight (because it was perfectly round) I'd be pretty surprised.
If you look closely at the ball you can probably see that some sections of the skin are thicker than the others, which is what causes the problem (I think, anyway).
Unread 17-01-2004, 00:30
duckshepherd's Avatar
duckshepherd duckshepherd is offline
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
duckshepherd is an unknown quantity at this point
Send a message via AIM to duckshepherd Send a message via MSN to duckshepherd Send a message via Yahoo to duckshepherd
The balls will never be completely uniform. The end of the ball where the hole is has slightly more weight, due to the utilization of thicker rubber at the inflation point. The ridges also play a part in manipulating the direction the ball rolls. There are all sorts of imperfections in the walls, but the effects are negligable when it comes to using the balls in short rolling distances.
By the way, were we supposed to get a plug or something for the ball? Our team didn't find anything in our kit that plugged up the hole for the big yellow ball.
-Jeremy Egger
Freshman-"Could you hand me that thing that makes that clickety noise when you turn it?"
Senior-"You mean the ratchet?"
No, I refuse. Wait, what? Did you say chicken and cheese? Alright then...
Unread 18-01-2004, 01:30
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
I guess I did not explain the situation quite right:
When I say it dosent roll straight, I mean REALLY not straight. Like, you give it a push (even a hard one) and it will roll for a little while, then sometimes make a 90 degree turn, or even roll back to where it came from.
This is much more than the ridges or plug could do (we are using a bolt as a plug, and when the ball comes to rest, the bolt is on the side, no where near to the bottom).
Unread 18-01-2004, 01:35
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
LoL, are you sure its not the floor? jk. Well thats odd, I havent been rolling my team's ball around so I don't know for sure, but I don't think that should happen. Maybe you haven't fully inflated it.
pi is exactly 3
IM me at: zmstr265
Unread 18-01-2004, 09:55
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
It actually could be the floor. What type of surface are you rolling it on? Carpet? Concrete? Tile?
Unread 18-01-2004, 14:41
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Uphill?
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 18-01-2004, 14:46
the laws of physics are still in effect - an object in motion tends to stay in motion
what you dont realize is the material that is used in the 2X balls warps time-space
so within its own frame of reference it IS rolling straight, and the rest of the world is warped
thats why you are seeing what appears to be odd random motion.
Unread 18-01-2004, 20:47
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
I'm rolling a fully inflated (30 inch) ball on a flat cement floor. I don't think there are any space-time problems either, because no other balls (or any form of matter) display any erratic motion in the same place.
I think its something like that - it just seems pretty extreem to me.
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Rambots Final Robot (no drum roll please....) archiver 2001 3 24-06-2002 01:08
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
ksc - ball bots ohm my katie86 Regional Competitions 8 10-03-2002 22:52
