Go to Post Speaking about healthier, the Texas air was sooooooooo much cleaner than NJ air, I felt my life expectancy being extended another 5 years. - The Chinese Guy [more]
Unread 13-01-2004, 22:49
mzitz2k's Avatar
mzitz2k mzitz2k is offline
Robotics Fiend
AKA: Matt Zitzmann
None #0302 (Mechanical Dragons)
Team Role: Student
mzitz2k will become famous soon enoughmzitz2k will become famous soon enough
Send a message via AIM to mzitz2k
Optimal Direction of the Drill and Chips
Hi,
Anyone know what is the optimal direction for the drills and chips to spin in? When I say "optimal" I mean, which direction has the higher amount of RPM's. Also, please specify how you are looking at the motor (for both the drill & chip) - are you looking at it as if the output shaft is pointing towards or away from you?
I figure the drill motor spins optimally in the clockwise direction (when the output shaft is pointed away from you) because that is the direction drill motors do more work. Just thought I would run this by the forum anyways though!
Thanks for your help.
Matt
Team 302 - "The Mechanical Dragons"
Engineering Inspiration Award - Western Michigan Regional (2004)
Division Champions - Newton Division (2003)
Regional Champions - Great Lakes Regional (2003)
General Motors Industrial Design Award - Great Lakes Regional (2002)
Motorola Quality Award - Buckeye Regional (2002)
Regional Finalists - Buckeye Regional (2002)
Division Finalists - Newton Division (2001)
Regional Finalists - West Michigan Regional (2001)
Unread 13-01-2004, 23:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Optimal Direction of the Drill and Chips
You are correct in your assumption with the drill motors. I don't know how much slower they spin though, in reverse.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-01-2004, 04:59
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
um, i'm pretty sure they both spin the same speed in both directions. considering it's the same current, driving the same motor, just the other direction
Unread 18-01-2004, 06:43
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
http://www.chiefdelphi.com/forums/showthread.php?t=2140 (Ken Leung and Joe Johnson's posts)
http://www.chiefdelphi.com/forums/sh...ad.php?t=23050 (Andy Baker's post)
http://www.chiefdelphi.com/forums/sh...ad.php?t=17895 (thread concept)
If you don't know the answer, don't reply as though you do.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 18-01-2004, 10:06
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I'm actually pretty sure the drill motors will rotate at the same RPM's in either direction, since in an actual drill, the direction of the rotation does not matter, it's simply reversed. I believe Lord Nerdlinger is correct, that the current is the same in each direction, so the RPM's will not change, since the gearing is the same. I'm not sure about the chip motors, but I'm assuming they are the same situation as the drill motors.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 18-01-2004, 14:22
Generator of Entropy
FRC #2973 (The Mad Rockers)
And if you don't know the answer, don't post in support of someone else who doesn't know the answer!
We've gone through this every year guys - The drills are not symmetric, the CIMS are pretty close. Read the old posts - FotoPlasma put them right in front of you, you don't even have to search for them (heaven forbid anyone would search for an answer first).
Unread 18-01-2004, 15:01
President, VEX Robotics, Inc.
In support of Gary and Fotoplasma, the drills most definitely do not spin the same speed in reverse. The reason is the wind angle of the windings. They are biased by about 10 to 15 degrees in order to give better performance while drilling. You can tell when you operate an actual drill that the reverse is slower. There is great debate on these fori about if it matters that the speed is different. Our team thinks the difference is significant enough to make sure the drills are pointing in the same direction.
The CIM motors are close enough to the same speed that we have not done anything specifically to make sure they are pointing in the same direction.
-Paul
Unread 18-01-2004, 15:18
Gabriel Gabriel is offline
#1409 (Fightin' Llamas)
Gabriel is just really niceGabriel is just really niceGabriel is just really niceGabriel is just really nice
Send a message via AIM to Gabriel
You can test this yourself fairly easily (although following the steps below might classify as a Very Bad Idea). First, put the motor in a clamp or find some other way to prevent it from jumping suddenly. Use clip leads to wire a drill motor to a speed controller (make sure the fan leads on the Victor are wired to the input terminals or to a variable power supply and be very careful to avoid shorts), use clip leads to wire the speed controller to the Maxi fuse block and then to the battery. Obviously you want to use proper wire gages, but for a very short test at no load clip leads should be okay (if they're not, you'll know pretty quickly). Attach the PWM cable to PWM-1 on the controller and slowly pull the joysytick forward, and then in reverse. You'll notice immediately that one direction is definitely faster. Since the leads on the drill don't appear to be marked, it is possible that you will wire them backwards and reverse will be faster, in this case just swap the +V and GND wires on the output terminals of the speed controller.
Unread 18-01-2004, 15:35
Cory's Avatar
AKA: Cory McBride
All technicalities aside, it is very easy to see that they dont operate at the same speed in forward and reverse. For the last 3 years we've uses a 2 drill drive system (3 drill, in 2002) Every year, we could NEVER drive in a straight line, with the exact same gearing for both motors.
2001-2004: Team 100
Unread 18-01-2004, 15:38
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Actually the leads of the drills are marked. If you look carefully there is a postive mark on the one side of the drill motor.
Unread 18-01-2004, 15:42
Really? I'll have to look again. I figured that they had to be but I couldn't see any markings.
Unread 18-01-2004, 15:45
Adam Y.'s Avatar
Adam Y.
no team (?????)
I was fairly sure of it unless I was dellusional. Though it does make sense since hooking those motors up backwards would result in a drill that doesn't drill very well.
Unread 18-01-2004, 19:05
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
Our team took some measurements with a strobe in preperation for building a quad motor robot. I do NOT believe these numbers actually reflect peak performance, I'm only providing them to give a ballpark idea of what kind of rpm differences were talking about. We used a speed controller ON last years robot (read: we don't know what our pwm in these tests actually was) and we used fairly dead batteries. Your results may vary... SIGNIFICANTLY.
Tests conducted with 2003 equipment.
Test One RPMs(battery ~11.2V)
Drill in High:
Fwd: 1145 Rvs: 1005
CIM:
Fwd: 5331 Rvs: 5190
Test Two RPMs(battery ~12.6)
Drill in High:
Fwd: 1244 Rvs: 1094
CIM:
Fwd: 5670 Rvs: 5560
From memory: Forwards on the Drill was defined as clockwise looking down the barrel, as if you were using the drill. Forwards on the CIM was defined as the opposite. Clockwise as if you were looking at the face of the CIM. Please don't ask why.
To reiterate: It would be very foolish for anyone to design ANYTHING based on these actual numbers. We recognise that these numbers in some cases don't even remotely reflect spec. However, if you were wondering if this phenomina is real-- there you go. As for us, we more or less completely disreguarded this data in the consruction of our gearbox; I recommend you do the same.
Unread 18-01-2004, 21:01
VinceT's Avatar
VinceT VinceT is offline
FRC #1793 (Pilots)
VinceT will become famous soon enough
The drills and chips have optimal RPMs in opposite directions, quite handy in connecting them by a gear.
Vince
"No, try not; do, or do not; there is no try" -Yoda
"mmm beefy" - reffering to our proposed drive train for this year
Unread 29-01-2004, 14:16
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
There is a significant power difference under load as well
The difference in no-load rpm of the drill motors has been pretty well covered here, but it should be also be noted that there is also a significant difference in the horsepower the drill motors put out in the two directions. I roughly measured it with a dyno built by one of my team mates few years ago, and there was at least a 10% difference in power between forward and backward. Since we tend to drive our robots in both directions, it may not be worth chosing a motor direction for forward and backward on the robot, but as anyone will know who has driven a robot powered by drill motors only in a "symmetrical-looking" drive train, it IS worth the effort of trying to have both motors turn in the same direction for a given direction of robot travel. The non-symmetry of the Chias is much smaller than that of the drills, though.
Team 1062, The Storm, 2003
2003 Drills and Chips Chris Motors 3 12-10-2003 19:02
