Go to Post Another human taking a job that a robot could do... - Ryan Simpson [more]
Unread 18-01-2004, 16:43
dmellich dmellich is offline
AKA: Mr. E
FRC #1251 (TechTiger Robotics)
dmellich has a spectacular aura aboutdmellich has a spectacular aura aboutdmellich has a spectacular aura about
Re: IR sensors
Originally Posted by KevinB
No, the "bicycle reflectors" you are referring to are the Team Color lights that must be mounted to your robot. These will flash red or blue depending on which side of the field your robot is assigned to.
The IR Beacons were shipped in pieces and must be assembled per instructions. You are correct to say that a controller is needed -- Code is provided to use the EduBot controller for this purpose.
Let me see if I have this straight.
The IR beacon parts in the kit are enough to build the two units (one for the robot and one at the balls). The EDUrobot controller is used with the beacon unit at the balls. Only thing left to do is use the appropriate code for each side.
David M. Ellich
Team 1251, TechTiger Robotics
South Florida Regional Planning Committee
"It's Cool to be Smart"
Unread 18-01-2004, 17:42
CPUguy387's Avatar
CPUguy387 CPUguy387 is offline
AKA: Matt
#1189 (Breaking Pointe)
Team Role: Student
CPUguy387 is an unknown quantity at this point
Send a message via ICQ to CPUguy387 Send a message via AIM to CPUguy387 Send a message via Yahoo to CPUguy387
Re: IR sensors
In what direction do the resistors neeed to be placed? And which part is the FET?
M@
Unread 18-01-2004, 18:07
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR sensors
It doesn't matter which way the resistors are attached. The MOSFET looks like the picture on the front of the data sheet.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2004, 18:10
CPUguy387's Avatar
AKA: Matt
Team Role: Student
Re: IR sensors
THANKS! I just wanted to make sure, since I really don't feel like desoldering (it's such a pain!) Also, thanks for reminding me to switch pins 2 and 3, I never would've known (except when it didn't work!) Thanks again
M@
Unread 18-01-2004, 18:09
FRC #2429
Re: IR sensors
No, there is a beacon on each side of the field, both driven by one EDU-RC.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2004, 18:15
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Re: IR sensors
You have enough parts to build 2 beacons. Those beacons are placed on the center line of the playing field. Build one and power/controll it via your edubot.
That's the transmittor.
You then need to build the receiver for your robot.
Unread 18-01-2004, 18:30
CPUguy387's Avatar
AKA: Matt
Team Role: Student
Re: IR sensors
Where can I reorder another FET? One of the ones I had broke when I was trying to desolder it and switch pin 2/pin 3
M@
Unread 18-01-2004, 18:37
FRC #2429
Re: IR sensors
Digi-Key has 'em. The part number is IRL3103-ND.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2004, 12:27
Re: IR sensors
The beacon parts are for the two beacons that will be on either side of the field. Neither gets mounted on the robot itself. Drive the beacons with the EDU controller running the beacon software provided at the IFI web site (labeled "IR Tracking Code - Kevin.org").
The robot gets just the one piece IR sensor (4 are assumed in Kevin Watson's code) hooked directly up to digital inputs 1-4. Drive these with the navigate software also in the download above.
Unread 20-01-2004, 21:13
CPUguy387's Avatar
AKA: Matt
Team Role: Student
Re: IR sensors
We ordered 2 more FETs just incase. Before I put the one on my second beacon, I just wanted to make sure which digram is correct. Is this one still wrong? http://www2.usfirst.org/2004comp/Inf...ng_diagram.pdf Should I still reverse the pins 2 and 3? I just wan to make sure again before I order more.
M@
Unread 21-01-2004, 09:18
Re: IR sensors
That circuit is incorrect.
Luckily the FET seems to be internally protected against hooking it up incorrectly or teams would have been burning them out right and left.
On the FET looking at the front (with the metal ground plate at the back)
pin 1 on the left goes to the white (signal) wire on the PWM cable from the EDU controller.
pin 2 goes to the negative side of the circuit you built.
pin 3 goes to the black PWM wire (common or ground) from the EDU controller.
You can see an updated circuit diagram Kevin Watson posted at http://kevin.org/frc/ beacon_transmitter_2.pdf
You can only see your circuit running with a digital camera, or by hooking up one of the IR sensors to a digital input like 6 and adding a printf to print the value of rc_dig_in06 in the beacon code.
Unread 27-01-2004, 00:59
Oode Oode is offline
Oode is an unknown quantity at this point
Re: IR sensors
Unfortuantely, even with the wrong circuit, you will still see the LEDs glow in the camcorder, in fact, the circuit actually functions with the Source and Drain swapped, but the resistors get REALLY hot. ( I tested it with the IR reciever and a scope, and the signal is there, just not as clean and not as far a range)
So why won't First fix the document error?????
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
