Go to Post I trust in Martus. - Petey [more]
Unread 15-01-2004, 16:41
alexrobotics alexrobotics is offline
alexrobotics is an unknown quantity at this point
IR sensors
What did the IR sensors come in or what do they look like? We are confused. If you have any information that would be great.
Unread 15-01-2004, 17:55
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: IR sensors
The IR sensors came in the padded envelopes (the same one as the IR LEDS)
They are small, black, 3-leaded parts with a rounded dome on one side.
Unread 15-01-2004, 18:04
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR sensors
They look like this.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2004, 13:18
dmellich dmellich is offline
AKA: Mr. E
FRC #1251 (TechTiger Robotics)
dmellich has a spectacular aura aboutdmellich has a spectacular aura aboutdmellich has a spectacular aura about
Re: IR sensors
Ok, we found the "hardware" for the IR sensor. However, we're not sure about the mounting board shown on the instructions. Is it the one that is in the padded envelope? If so, do we cut it down to a smaller size? Any help is much appreciated.
Unread 16-01-2004, 13:39
FRC #2429
Re: IR sensors
I think the piece of vectorboard is used to make the beacon (make sure you read the thread about the schematic error before you build this). The sensors are meant to be directly soldered to the end of a PWM cable or inserted into a connector that you build (this is what I did).
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2004, 14:06
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: IR sensors
Yeah we just used a bandsaw to cut our PCB to the exact size they had in the instruction.
By the way, remember that the instructions from the kit are wrong when it comes to wiring the transistor.
http://www.chiefdelphi.com/forums/sh...ad.php?t=23878
Unread 18-01-2004, 13:56
AKA: Mr. E
Re: IR sensors
Thanks for the help, we're going in the right direction now although we need clarification/help on the rest of the IR system.
As described we understand the IR sensors on the robot "seek out/home in on" the sensor(s) located near the 10 point balls. Did we receive the parts needed to create the "sensor" at the 10 point ball location? Are they the square "reflectors" (look like bicycle reflectors w/wires- 4ea) in the kit? If so, what are they connected to? Given Kevin's posts relating to "code" for these sensors (at the balls) it sounds like there is some type of "controller" (computer?) running this end of things. Correct?
Again, thanks for the help.
David M. Ellich
Coach, Team 1251
TechTigers/The Revolution
"Technology for the 21st Century"
Unread 18-01-2004, 14:40
CPUguy387's Avatar
CPUguy387 CPUguy387 is offline
AKA: Matt
#1189 (Breaking Pointe)
Team Role: Student
CPUguy387 is an unknown quantity at this point
Send a message via ICQ to CPUguy387 Send a message via AIM to CPUguy387 Send a message via Yahoo to CPUguy387
Re: IR sensors
I also was wondering if the PWM connectors and the short wires depicted on the diagram that came with the beacon instructions are in the envelopes, because the one I have doesn't include them. Are they possible in the other envelopes for the other sensors. Also, Kevin, I'm not exactly sure how to wire up the sensor for our robot, such as you depicted. What does the sensor connect to? And, how does that connect to the controller? Thanks
Unread 18-01-2004, 14:44
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Re: IR sensors
No, the "bicycle reflectors" you are referring to are the Team Color lights that must be mounted to your robot. These will flash red or blue depending on which side of the field your robot is assigned to.
The IR Beacons were shipped in pieces and must be assembled per instructions. You are correct to say that a controller is needed -- Code is provided to use the EduBot controller for this purpose.
Unread 18-01-2004, 14:57
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Re: IR sensors
You were given enough parts to make 2 Beacons.
In the sensor bag you will find Printed Circuit board x1, IR Transmittors x10 resistors x8, switches x2, and connectors x2.
Print out the document http://www2.usfirst.org/2004comp/Inf...ng_diagram.pdf
And it will assist you in the parts identification.
Phil
Unread 18-01-2004, 15:16
FRC #2429
Re: IR sensors
Phil
This document is still incorrect. Pin 2 and 3 of Q1/"HexFET" need to be reversed for it to work.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2004, 16:43
AKA: Mr. E
Re: IR sensors
Let me see if I have this straight.
The IR beacon parts in the kit are enough to build the two units (one for the robot and one at the balls). The EDUrobot controller is used with the beacon unit at the balls. Only thing left to do is use the appropriate code for each side.
David M. Ellich
Team 1251, TechTiger Robotics
South Florida Regional Planning Committee
"It's Cool to be Smart"
Unread 18-01-2004, 17:42
CPUguy387's Avatar
AKA: Matt
Team Role: Student
Re: IR sensors
In what direction do the resistors neeed to be placed? And which part is the FET?
M@
Unread 18-01-2004, 18:07
FRC #2429
Re: IR sensors
It doesn't matter which way the resistors are attached. The MOSFET looks like the picture on the front of the data sheet.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2004, 18:09
FRC #2429
Re: IR sensors
No, there is a beacon on each side of the field, both driven by one EDU-RC.
-Kevin
Kevin Watson
http://kevin.org
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
