Go to Post As they say... I'd rather be lucky than good any day (especially Saturdays). :) - JVN [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-01-2004, 19:03
VinceT's Avatar
VinceT VinceT is offline
FRC #1793 (Pilots)
VinceT will become famous soon enough
Question Sprockets
Does anyone have any knowledge of a sprocket supplier that is easy to order from? We specifically need a 19 tooth #35 type A sprocket. Our team has already tried looking at smallparts.com, sdp-si.com, martinsprocket.com, grainger.com, globalspec.com, and bostongear.com (i think). all of these either haven't had type A #35 sprockets or, we don't know how our team, not being a company, can buy them, any assistance is appreciated.
Vince
"No, try not; do, or do not; there is no try" -Yoda
"mmm beefy" - reffering to our proposed drive train for this year
Unread 18-01-2004, 19:22
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
Re: Sprockets
try http://www.mcmaster.com or http://www.mscdirect.com these are both companies that supply sprockets and other useful robotic items.
Unread 18-01-2004, 19:32
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Re: Sprockets
If you go to www.motionmro.com, the website of Motion Industries, you can search for gears to match your needs. Motion Industries is a distributor, so they can order any of the gears listed on their website and sell them directly to you.
I quickly put in your #35 sprocket with 19teeth and found 10 manufactured sprockets. Martin sprockets is listed as one of the companies that supplies this sprocket, and its part# is 35A19. There are also others made by Martin, Browning, Dodge-Reliance, Boston Gear, and UST Inc. Once on their homepage, click on mechanical>Chain&Sprocket>RollerChainSprocket> and then your specs. Hope this helps.
-Rc
Unread 18-01-2004, 19:42
VinceT's Avatar
FRC #1793 (Pilots)
Re: Sprockets
I think that will work for us, thank you very much, I had been searching for 3 days for a distributor of this, but couldnt find one, I appreciate the response.
Vince
Unread 18-01-2004, 23:07
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Re: Sprockets
Vince
Vince,
Give Martin Sprocket a call. We have worked with them in the past. They have been extremely helpfull. They even came to watch us compete at the Peachtree Regional Last year. If you continue to have problems contacting them let us know and we can put you in contact with the right people. Good luck!
- Gene Falendysz
sprockets BBFIRSTCHICK Technical Discussion 21 09-02-2003 01:01
modifying sprockets gail OCCRA 3 05-10-2002 12:13
Chief Delphi sprockets archiver 2001 23 24-06-2002 01:46
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
