Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-01-2004, 19:32
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Re: Sprockets
If you go to www.motionmro.com, the website of Motion Industries, you can search for gears to match your needs. Motion Industries is a distributor, so they can order any of the gears listed on their website and sell them directly to you.
I quickly put in your #35 sprocket with 19teeth and found 10 manufactured sprockets. Martin sprockets is listed as one of the companies that supplies this sprocket, and its part# is 35A19. There are also others made by Martin, Browning, Dodge-Reliance, Boston Gear, and UST Inc. Once on their homepage, click on mechanical>Chain&Sprocket>RollerChainSprocket> and then your specs. Hope this helps.
-Rc
Unread 18-01-2004, 19:42
VinceT's Avatar
VinceT VinceT is offline
FRC #1793 (Pilots)
VinceT will become famous soon enough
Re: Sprockets
I think that will work for us, thank you very much, I had been searching for 3 days for a distributor of this, but couldnt find one, I appreciate the response.
Vince
"No, try not; do, or do not; there is no try" -Yoda
"mmm beefy" - reffering to our proposed drive train for this year
sprockets BBFIRSTCHICK Technical Discussion 21 09-02-2003 01:01
modifying sprockets gail OCCRA 3 05-10-2002 12:13
Chief Delphi sprockets archiver 2001 23 24-06-2002 01:46
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
